Author Topic: KDX 250 flywheel  (Read 6568 times)
KDX 250 flywheel
« on: October 21, 2013, 10:27:25 am »
Looking for a flywheel / rotor for a KDX 250 83 - 85
Part No 21007-1065
Can also be identified  by FP 5173 which will be stamped on the flywheel. This is a flywheel ID No
Any help would be appreciated, it’s for a ‘keeper’
Re: KDX 250 flywheel
« Reply #1 on: October 21, 2013, 10:32:17 am »
Airbox's finished are they? 8)
« Reply #2 on: October 21, 2013, 10:37:41 am »
Come on Geoff, how many other KDX's run the same flywheel  ;-)
« Reply #3 on: October 21, 2013, 11:29:16 am »
He's disappeared to go check the mail in his RM370 post box. ::)
Also looking for a kickstart knuckle
« Reply #4 on: October 21, 2013, 12:06:11 pm »
Officially only the 83, 84 & 85 KDX 250's ran the same flywheel.
The US didn't receive the KDX in 85 so doesn't show up on their lists but it is the same bike as the 84.
It seems the knuckle was only for the 84 & 85 model KDX 250 but the shaft came from these models so the complete kick start assembly from these models should be okay.
Any parts or leads appreciated
Model Count = 11
KDX200-A1 83 200 KDX200 OFF ROAD
KDX200-A2 84 200 KDX200 OFF ROAD
KDX200-A3 85 200 KDX200 OFF ROAD
KDX200-C1 86 200 KDX200 OFF ROAD
KDX250-B3 83 250 KDX250 OFF ROAD
KDX250-B4 84 250 KDX250 OFF ROAD
KXT250-A1 84 250 TECATE SPORT 3 WHEEL ATV
KXT250-A2 85 250 TECATE SPORT 3 WHEEL ATV
KXT250-B1 86 250 TECATE SPORT 3 WHEEL ATV
KXT250-B2 87 250 TECATE SPORT 3 WHEEL ATV
KX250-C1 83 250 KX250 MOTOCROSS
Me old letterbox is so yesterday,
Still have to put the new one up, after all, thats all RM's are good for
« Reply #5 on: October 21, 2013, 12:16:37 pm »
If it is correct that the 200 and 250 share the same shaft, then I'm pretty sure that I will have a kiskstarter knuckle for you.
« Reply #6 on: October 21, 2013, 12:41:38 pm »
Will try to gather some details to determine how compatible it will be.
« Reply #7 on: October 21, 2013, 05:15:27 pm »
Bastard.....bout time you mowed the grass.......wait till I tell Roger!!!!
Offline Grunter215
« Reply #8 on: October 21, 2013, 05:30:48 pm »
Geoff, if ya want an alloy one,use knuckle/lever from '89 KX250, from memory just need washer/spacer behind it.
« Reply #9 on: October 21, 2013, 05:35:30 pm »
Thanks Grunter, that's something we will look into.
Lots of post 90 flywheels on US e-bay but unsure of how compatible they would be with the (much) older model. Anyone have this sort of weird knowledge?
Yours isn't the only job I've been having trouble getting back to (just ask me missus)
Plus need a side stand assembly
« Reply #10 on: October 21, 2013, 05:41:52 pm »
To be found on these models
Part # = 32043-1114
Part Description = STAND BRACKET
Model Count = 5
Part # = 34024-1104
Part Description = SIDE STAND
Model Count = 5
Offline kdx 175
« Reply #11 on: October 21, 2013, 06:44:22 pm »
I have a 1983 kdx 200 fly wheel on my kdx 175 the timing mark don't line up that's all and I have a side stand mount 1983 200
« Reply #12 on: October 21, 2013, 06:53:59 pm »
There's a lot of similarity between the various model of KDX200 FWs (and 175 as noted), I wouldn't be surprised if there was similarity between the various models of KDX250.
« Reply #13 on: October 21, 2013, 09:43:28 pm »
I had wondered about the early 200 flywheels fitting the KDX 175's
I tried an 86 200 flywheel on my KDX 175 but the crank taper had grown in size by then. Stator plate was slightly bigger too.
I will have to check if the 86 200 flywheel taper is similar to the 250 taper
