Author Topic: YZ 490  (Read 3947 times)
Offline bingil 6
YZ 490
« on: June 01, 2008, 01:38:24 pm »
Okay all you Yamaha Gurus, Iv'e got a YZ 490 with a rear disc brake which to me looks like it's original ,what years & models did these bikes come fitted with rear discs? Cheers Lou
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: YZ 490
« Reply #1 on: June 01, 2008, 02:02:22 pm »
yz490? or WR500?
the WR came with the rear disk as standard and is virtually the same bike. it's either the WR and your confused or someones done a conversion.
"flat bickie"
Offline bingil 6
Re: YZ 490
« Reply #2 on: June 01, 2008, 02:12:56 pm »
Someone could have dicked around with it, I bought it cheap a while ago and havn't gone near it since then but Iv'e always wondered what model it was, when I get home next I'll get the numbers off it to determine what it realy is, Thanks for the info Cheers
Re: YZ 490
« Reply #3 on: June 01, 2008, 04:14:05 pm »
could be a late model YZ490 as they went up to around 1987 "T" Model so it could be standard.
lms6201
Re: YZ 490
« Reply #4 on: June 01, 2008, 06:54:25 pm »
all zy 490,s even up to the last one  in 1990 had drum rear , easy to tell if it,s a wr ,(disc,s)   with the 10gallon tank and usd forks and deltabox arm with snail cam axle  adjusters  , 82,j  83,k had angle exhaust port and single downtube frame , 84 on center ex port and wishbone cradle , front disc from 85 i think
Offline bingil 6
Re: YZ 490
« Reply #5 on: June 09, 2008, 09:32:45 am »
Finaly got some time so here's the Frame # 1LV-000660, Engine # 5L5-000007, & It does'nt have snail cam adjusters Cheers
Offline caps 999
Re: YZ 490
« Reply #6 on: June 09, 2008, 09:38:07 am »
according to y-pic the frame is 86 yz490 and the engine is pre production 81 it465 its telling me the engines started at  5L5-000101
MUGEN power
