Author Topic: sc500 gearbox  (Read 3458 times)
Offline asasin
sc500 gearbox
« on: October 19, 2013, 06:15:21 am »
All you Yamaha gurus , will a DT2 250 5 speed go into a SC500 gear housing . I measured the casings and they are the same width
If in doubt ,WIND IT OUT
Offline asasin
Re: sc500 gearbox
« Reply #1 on: October 21, 2013, 01:34:17 pm »
I have since found out SC500 and dt/mx 360 are the same , are these the same as DT II 250
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: sc500 gearbox
« Reply #2 on: October 21, 2013, 02:20:01 pm »
The 74 model DT250/360 box and the silver or yellow model MX250/360
Should all swap around with each other and the big SC500 no problems
At all.
Other models can be made to work also but may differ in the shift fork/drum
area ...
Cheers from Oz bro...
"flat bickie"
Offline asasin
Re: sc500 gearbox
« Reply #3 on: October 21, 2013, 02:26:37 pm »
Thanks Vandy , i knew some wiz would know . I may as well do it while it is apart
John
Re: sc500 gearbox
« Reply #4 on: October 26, 2013, 07:11:15 pm »
Ive heard the go is the dt gears for dirt track and mx gears for motocross . its the 360 clusters you are after the shafts are different to the 250's . the 360 's will bolt in fine the balancer has to come out though . Iain
