Author Topic: honda XL500s engine  (Read 7381 times)
NGK
honda XL500s engine
« on: October 17, 2013, 08:48:23 pm »
sold
« Last Edit: December 15, 2013, 11:14:49 am by NGK »
Offline bishboy
  • Toowoomba
Re: honda XL500s engine
« Reply #1 on: October 18, 2013, 11:21:00 am »
What year is the motor?
And does any know will it fit in a KLX250 frame without hacking the frame??
Offline g465b
« Reply #2 on: October 18, 2013, 12:23:35 pm »
the XL500 engine is approx  360mm long and  520mm high,the KLX cradle is approx 20mm to short and just not tall enough.there were two xl500 eng /klx hybrids at cd7 or 8,so they  will fit    g.
Offline Digga
« Reply #3 on: October 18, 2013, 01:00:37 pm »
If you go squeezing in a big 500 engine into a KLX 250 frame, then where does that fit witin the VMX classes? How does that work, Evo???
Offline bishboy
  • Toowoomba
« Reply #4 on: October 18, 2013, 02:44:44 pm »
As long as the engine comes from a twin shock bike, it will fit evo
Sounds like there will be some cutting and shutting involved, would prefer not to cut up the frame....
What about fitting a XL350 engine?
Don't know a lot about four strokes, but I understand that there are plenty of aftermarket kits, cams etc for both the 500 and 350 and can be made to make good horsepower?
« Reply #5 on: October 18, 2013, 02:49:45 pm »
They fit KLX without much problems
Offline steve234
« Reply #6 on: October 18, 2013, 04:08:17 pm »
PM sent regarding forks
Steve
Bultaco M106 Astro
« Reply #7 on: October 18, 2013, 06:06:05 pm »
theres a tread on this site for the 500 motor in the klx250 frame but im sure there was a lot of cut and shutting to be done like extend the top tube of the frame. there was a tt350 powered klx on here as well and it would be an easier conversion to do
Offline Andrew L
« Reply #8 on: October 18, 2013, 06:48:09 pm »
Will the 500 fit in a xl250s frame of the same era
Offline silverfox
« Reply #9 on: November 26, 2013, 07:07:22 pm »
G/day mate. Best I could offer you would be $300.00 plus the ride to me. I have one in a 79 husky frame that I am going to rebuild, so would be using it as a spare. Would not make sense for me to spend any more, as I would be better putting the money into my own rebuild, as this one will probably need one as well. If that all makes sense!!
To many, 72 Husky CR400, 73 Husky CR250, 77 RM370 x 2, 77 & 79 Honda CR125, 77 AW400, 82 CR480, 87 430 auto, 79 Honda 500/ Husky hybird
Offline VMX Andrew
« Reply #10 on: November 26, 2013, 07:19:30 pm »
Im interested... Just let me have a think about it for a while ok ???
