Author Topic: HEADS-UP $30 Welding Tables at SUPER CHEAP  (Read 2151 times)
« on: October 07, 2013, 02:54:51 am »
I finally got around to assembling this last night.
They were on CLEARANCE SALE at Super Cheap, a few weeks ago for $39.95
Then three weeks ago reduced to $35
Then last week reduced to #$30
The idea is you can bolt or clamp your job to it.
Then tilt it 90deg from a horizontal position to a vertical position, or 180deg back
the other way, or anywhere in between. You can walk all around your job for easy access to it.
Getting optimum angle to run your weld at really helps improve your welding outcome.
Well,,,,,,,,,,,,it does mine 8)
Good for bolting engines and components to as well, for assembly, porting etc, etc.
Looked at a couple of others, very similar but they were around the $230--$250 mark.
For 30 bucks, I am very happy.
Would pay to ring around first to check for availability though.
I have five store outlets ranging in 10 minutes to 3/4 hour drive, Still a few left around Newy.
There is also a few angle bits etc, that fit onto the table for square jigging etc.
« Last Edit: October 07, 2013, 03:28:18 am by Mick D »
