Author Topic: Suzuki TM 250 project  (Read 1673 times)
Offline Richo52
« on: October 03, 2013, 08:21:51 am »
The motor and GMC pipe are going back to NZ where I purchased them from lol.......Whats left you may ask?
75 frame and swingarm $150
74 swingarm excellent unmolested condition in black primer $100
74 TM 125 Tank with cap and petcock $120
250 oil tank and associated bits $100
Good triples sliders and lower legs in pieces $125
OR THE LOT $400 plus shipping cheers Richo.
SOME BIKES AND CARS
Offline Richo52
Re: Suzuki TM 250 project
« Reply #1 on: October 04, 2013, 02:51:50 pm »
Update,oil tank no longer available.
MORE motor parts available.
1.Nos barrel Std bore with piston,piston rings,gudgeon pin and small end bearing suit 1974 TM250L $300.
2.Bottom end 74 TS 250 bottom end in excellent condition,with flywheel and ignition cover,clutch cover etc ready to use.$250
3.Set of TM250 74 cases bead blasted $100
$.Nos 2nd and 4th driven gears and 1 shift fork and nos gearshift shaft $100.cheers Richo
SOME BIKES AND CARS
