Clubroom
Tech Talk
Fork Oil quantity for 1984 XR200R
Topic: Fork Oil quantity for 1984 XR200R (Read 3451 times)
Sweep Rider
C-Grade
October 01, 2013, 11:30:00 am »
Hi out there....
Would anyone know the amount of fork oil for a 1984 XR200R.
Am getting ready for Murphy's Creek Vinduro this weekend and I think the forks are empty....very bouncy.
Will try and find a free download for the manual however am running out of time.
Cheers Terry
1974 TM 250, 1974 XL 250 Moto Sport, 1976 RM 370A, 1976 RM 125A, 1977 IT 250D, 1978 SP 370, 1984 XR 200R
80-85 husky
Re: Fork Oil quantity for 1984 XR200R
October 01, 2013, 11:43:25 am »
simply pull the springs out, compress the forks and fill to 180mm from the top. that will get you out of trouble.
use 10 weight or if your light try ATF or mix a bottle of 5 and 10 wt
Canam370
October 01, 2013, 12:13:32 pm »
Specs require 355cc per leg. If there's little or no oil in there you might want to invest in some seals. Pretty likely that the oil departed via some crook seals.
Sweep Rider
C-Grade
October 01, 2013, 01:10:06 pm »
Thanks guys.
I will drain and fill with the required amount. I'm sure it needs new seals however that will have to wait until after this weekend.
I've used ATF before and seems to work well. I'm 82 KG without riding gear.
Cheers T
Clubroom
Tech Talk
