Author Topic: YZ125C frame, wheel & footpegs.  (Read 1897 times)
« on: September 29, 2013, 06:24:42 pm »
Frame is quite good, not perfect.
Has had a repair to the LHS upper rear engine mount, muffler mount is tweaked and muffler mount thread is stripped. No other apparent repairs or damage.
Some pitting from old surface rust. Has been painted by a retard/someone wearing concrete boots.
Lower frame rails very good, footpeg holes not flogged out.
Had the dealer footpeg mount mod.
$75.
Rear wheel has been painted both white and purple at different times in the past - partially stripped. One minor bend in the rim, seems very good otherwise.
Sprocket bolt threads good.
Correct externally lipped rim (18x1.85).
Bearings OK.
Will also suit YZ125A/MX125A, but has 10mm studs for sprocket rather than the 8mm of the earlier bikes (just use a YZ125C sproecket and you're sweet).
$50.
Pair of footpegs. Good used condition, holes a bit sloppy but not too bad..
$20.
Will do a deal if you take the lot.
In Yass, southern NSW.
Nathan. 0400023847
Offline reece
Re: YZ125C frame, wheel & footpegs.
« Reply #1 on: September 29, 2013, 06:45:07 pm »
Will the rims fit a yz465 1980 model.
« Reply #2 on: September 29, 2013, 06:51:16 pm »
no
« Reply #3 on: September 29, 2013, 08:51:51 pm »
PM sent re wheel
Offline Richo52
« Reply #4 on: September 30, 2013, 08:19:20 pm »
I have a good condition Swingarm  with new bearings and nice paint if it helps out whoever buys the frame.Cheers Richo.
SOME BIKES AND CARS
« Reply #5 on: October 02, 2013, 09:00:28 pm »
Wheel photos:
Footpeg photo. Third one is MX-A, I think. good nick.
Should add that Mainline is sorted. :)
