Author Topic: Garage cleanout!!! Bike Sale!! Pics of YZ250 and KX250 added, 490 pics to come  (Read 11397 times)
Offline gsr
Hi Guys,
A few bikes to get rid of Haven't been ridden for a couple of years so it is time to clear them out. Pm for pics. All bikes have been described as best as my memory can deal with.  :)
YZ250 '89
Was ridden in Viper series 2 years ago and then engine was rebuilt and hasn't been used since. Ready to race.
Rebuilt engine including new rod, bearings, piston and rings, clutch. All engine cases hydro blasted.
Nos plastics fitted (have a few scuff marks from being ridden)
New seat cover.
New swing arm, shock and head stem bearings.
Chain and sprockets good.
Renthal Bars.
Tank is discoloured.
Probably plenty of bits that I have forgotten to mention.
$2000
YZ490 '86
This bike hasn't been ridden for about 3 or 4 years. Pulled it out and put a NOS piston and rings in it. Fired it up but it seems to have an electrical problem, it starts easy enough and runs but once warmed up it starts to pop and bang a bit. Fuel tank is discoloured.
Had a NOS cylinder fitted before doing 2 seasons of Viper, and engine was also rebuilt with all new bearings, clutch plates and engine cases hydro blasted. All suspension, swingarm and head stem bearings were replaced. Had new plastics fitted and just about everything else replaced. The frame had already been painted black and the seat recovered in black also when I bought it so I didn't bother changing them back to red. Had a new 38mm mikuni carb fitted because I couldn't find spares for the original 40mm carb.
Has plenty of spares including the original cylinder, head and some pretty crappy engine cases. Spare CDI and ignition which may fix the problem but I cant be bothered :)
$1500
KX250 '89
This one has a lighting coil fitted and has lights to comply with REC rego so I have a long range tank on it and barkbusters and stand is fitted also.
Engine has just been fully rebuilt with an FMF aftermarket rebuild kit from the states which included new crank, rod, piston, rings, bearings and gaskets. Also put some new clutch plates in, replaced one of the engine cases because the drain plug was knackered and had a good primary drive gear fitted.
All the swingarm, head stem and shocks feel good. Brakes are good and chain and sprockets are good. Has a couple of small tears in the seat cover. The Exhaust has a fairly big dent in it and could do with repairing or replacing.
I also have the original tank and a spare rear guard and front number plate so it can be put back to the original MX style pretty quickly.
$1500
Bikes can be viewed in Pakenham Vic. The YZ490 is currently in stored in Sale but I will pick it up next weekend.
PM to arrange any inspections.
Alex
« Last Edit: September 29, 2013, 03:16:30 pm by getsmartracing »
Ex viper#86
Offline gsr
Re: Garage cleanout!!! Bike Sale!!
« Reply #1 on: September 29, 2013, 03:10:17 pm »
Pics of the YZ250
Ex viper#86
Offline gsr
« Reply #2 on: September 29, 2013, 03:15:12 pm »
Pics of KX250
Also has REC Rego until June 2014
Ex viper#86
Offline nada
Hmmmm I have the YZ's little brother, let me chew on it:)
Nada
Honda is the only way to roll!
PM sent regarding KX250.
Offline Glen08
Interested in the 490 thanks  :)
Offline Spanish Armada
pm sent re kx250
Offline mposs
pm sent re YZ
Offline gsr
KX250 SOLD!!!  :)
Ex viper#86
Offline yzhilly
  • Melbourne
Good hurry up and sell the other 2 before I buy them .Hilly
Viper #436
Offline gsr
You know you want them Hilly  ;D
Ex viper#86
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
I'm still reserving first dibs on the 490 it comes out of hibernation!!  ;)
Offline Yamahaha
  • Melbourne Vic
As of you could handle a 490 Brendan  ;D ;D ;D
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
Offline yzhilly
  • Melbourne
Good on ya Brendan I expect to see at Viper pre 90 next season .Im ruling myself out of the market .But that 89 YZ250 is spot on and cheap for a pre 90 race bike you could race at ravenswood next weekend . hilly
Viper #436
Peter Elliot said that he wants the 250 for sure!  I'm up for the 490
