Author Topic: Remove paint from plastic side covers.  (Read 12054 times)
Offline kdx Geoff
« on: September 23, 2013, 05:48:57 pm »
To freshen up the number area of my side covers l want to remove the paint that's on there.
Is there an easy way to get the paint off without damaging the plastic so l can repaint it/put on fresh vinyl or should l just sand it down smooth and paint over the top of what's left ?
Geoff
Offline steve7406
Re: Remove paint from plastic side covers.
« Reply #1 on: September 23, 2013, 05:58:50 pm »
Get them soda blasted
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline Paul552
  • HEAVEN #552
« Reply #2 on: September 23, 2013, 06:00:43 pm »
I got to do the same.
Does the soda blast dull the plastic?
Offline mustanggrahame
« Reply #3 on: September 23, 2013, 06:13:23 pm »
I've been told to use brake fluid. Bubbles the paint off with no effect to the plastic
Montynut
« Reply #4 on: September 23, 2013, 06:18:48 pm »
There is an 'orange' based paint stripper (Bunnings) which is plastic and fibreglass safe. I have used it on both without any damage to the base material. Naturally you can not leave the stripper on for excessive time and do not let it dry.
« Last Edit: September 24, 2013, 12:50:22 pm by Montynut »
Offline kdx Geoff
« Reply #5 on: September 23, 2013, 06:28:28 pm »
Brake fluid.
l should have remembered that  :o
l think you're right Grahame, wrecks paint and wont worry the plastic......and its in the shed.
Geoff
Offline Paul552
  • HEAVEN #552
« Reply #6 on: September 23, 2013, 06:32:13 pm »
Make sure you let us know how you go.
I have a number plate I need to do.
Offline kdx Geoff
« Reply #7 on: September 23, 2013, 06:54:16 pm »
pictures to come
Offline nada
« Reply #8 on: September 23, 2013, 07:06:37 pm »
There is an 'orange' based paint stripper (Bunnings) which is plastic and fibreglass safe. I have used it on both without any damage to the base material. Naturally you can leave the stripper on for excessive time and do not let it dry.
Use a citrus based product 3M produce it! Brake Fluid will weaken the plastic, you just wont see it, it will go brittle and snap.
If you want to bring them up like new, sand, heat and polish! i can put a detailed response on the process if you like?
Nada
Honda is the only way to roll!
Offline kdx Geoff
« Reply #9 on: September 23, 2013, 07:22:23 pm »
l have only got the brake fluid on the painted part of the cover, keeping my eye on it.
where does the heat come in ?
Offline nada
« Reply #10 on: September 23, 2013, 07:44:40 pm »
Ok My Process is:
Never use any alcohol based or harsh strippers like brake fluid products on PVC (Plastic) it will eat it alive, hardens and shortens up the ageing process:) always use a water based product, like a citrus 3M organic based paint strip.
Better yet, don't paint plastic, it looks shit.
Restoration process: Depending on the gauges and decay of the PVC will depend on how you much time you spend on each process.
1. Using 400 grit sandpaper ( Dry), sand back until mat finish, smooth and all gauges are gone or relatively gone, so your happy with the finish (I use an electric hand sander) . You can get a plastic welding kit or filler if your keen, but if your going to go to that extent www.plasticrenovations.com and contact me i'll get you a quote for restoration.
2. Using the 400/200 grit, start the wet and dry process and keep working until all smoothed out and stats to get a gloss, LIGHTLY apply heat via heat gun small sections at a time (this makes the molecules in the PVC fire up and start to rejuvenate)
3. Buy a Novis 1,2,3 pack from American eBay, ($50 delivered to your door) or if you can find equivalent in Australia let me know, i'm yet to find it! and polish the hell out of it, repeat stages as required.
4. Purchase a really good quality car polish (Maguires) from Autobarn and polish until a high mirror shine:)
Its time consuming, but it's worth it in the end:) Happy Polishing:)
My suggestion is, restore and old shitty piece first, as if you make a mistake with the gun, you wont be in tears!!!!!!!!
You can use acetone to seal the inside of a tank, swish it around and with a few nuts, bolts and screws to loosen and shit caked on the walls:)
« Last Edit: September 23, 2013, 07:48:46 pm by nada »
Nada
Offline Grunter215
« Reply #11 on: September 23, 2013, 07:51:23 pm »
"Bumper Stripper". Comes in aerosol can, washes off with water.
« Reply #12 on: September 23, 2013, 07:57:40 pm »
"grease and wax" remover works pretty well also without affecting the plastic.
Offline kdx Geoff
« Reply #13 on: September 23, 2013, 08:29:31 pm »
Thanks Nada
I've washed off the brake fluid and will see what else l have in the shed tomorrow  :)
Offline nada
« Reply #14 on: September 23, 2013, 08:37:08 pm »
Thanks Nada
Cool cool:):) shoot me  a line anytime you need some info:) I will put up some before and after shots of some of my creations also:)
Nada
