Author Topic: Yz 400 d fox air shock  (Read 2047 times)
Offline hagon_84
« on: September 21, 2013, 09:04:58 am »
I just pulled the air shock out of my bike to see how it is adjusted as many of you would know it has a valve at the top which looks like it will unscrew to fill the shock with oil and possibly with air?. Basically what I'm wanting to no is how much oil air or nitrogen? Does it require to suit a 90 kg rider mostly doin dirt track any help will be appreciated.  ;)
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Re: Yz 400 d fox air shock
« Reply #1 on: September 21, 2013, 11:41:58 am »
The valve is for nitrogen only, the pressure depends on your weight and speed, you need to experiment starting at around 180 psi. The big brass 2 sided nut on the end of the body is where you open the shock to service it, Use 5w oil the amount will be listed in a fox monoshock manual, I only have one for twin shocks. You can get a copy from Thor Lawson in the US.
Offline hagon_84
« Reply #2 on: September 22, 2013, 08:17:31 am »
Cheers for the info JohnnyO ill look into it today and make some mods cheers Al.
