Author Topic: Marzocchi Front Fork Parts  (Read 3079 times)
Offline oz555ktm
« on: September 13, 2013, 09:46:25 pm »
   Can any one tell me where I can get some Bushes for  Marzocchi front forks..
   Slider and Leg bushes for 41.7 and 40
   Slider bushes fit to the botom of the Slider ..
    Leg bushes fit just below the seals .
  Off a KTM 1982 to 1984  Normal forks
Offline b490
Re: Marzocchi Front Fork Parts
« Reply #1 on: September 13, 2013, 11:09:49 pm »
 Hey Dennis  ,
  3rd item down on list .....  is this what you looking for ??
http://www.enduroklassiker.at/artikel/index.php?mid=99&cat=2&sort=
Regards ,
                 Steve
« Last Edit: September 13, 2013, 11:20:00 pm by b490 »
Offline oz555ktm
« Reply #2 on: September 21, 2013, 10:18:40 pm »
  still in Need of Fork Bushes
     Top Bushes in leg Both 40mm and 41.7
« Reply #3 on: September 22, 2013, 07:46:42 am »
You can buy bronze bush that close to size at the bearing center and then machine to correct size. You may need to ream the last bit.
Offline Eldert
« Reply #4 on: September 29, 2013, 04:56:35 pm »
you can forget about Marzocchi bushings .
i had a friend who had the same problem with his 40 mm KTM forks
i did a little searching on Google and found that a few Yamaha road bikes had 40 mm Kayaba
forks with upper bushings in the fork slider ( V Max and a few others )
i never ordered some at the dealer so i could not compare dimensions .
the Yamaha part number is 3JJ-23125-00 . you might have to machine the slider to accept the Kayaba bushing .
if you go this route please let us know how it did work out
Eldert
Offline oz555ktm
« Reply #5 on: October 04, 2013, 08:00:25 pm »
   Thanks  Eldert
    Dennis
