Author Topic: Crank rebuild in Melbourne?  (Read 6860 times)
Offline Curtis
    • japspec.com.au
« on: September 10, 2013, 11:56:15 pm »
Just wondering if anyone can recommend a good shop that does crank rebuilds in the greater melbourne area? :) ThanKs!
Re: Crank rebuild in Melbourne?
« Reply #1 on: September 11, 2013, 07:53:12 am »
Save yourself the drama and send HERE
« Reply #2 on: September 11, 2013, 09:32:56 am »
Jeezus Lozza, the bloke would have to be mighty flucking good to warrant senting a crank to the Northern Territory ::). I'll stick with the bloke the factory motocross teams all go to and he's 10 minutes from my place.
« Reply #3 on: September 11, 2013, 11:39:51 am »
Can send your cranks  where ever you want to, don't worry me. Every crank that I've sent there (including about 20 Honda tin can cranks ) return with no run out and cost $50, that's all I want.
« Reply #4 on: September 11, 2013, 12:03:21 pm »
I wouldn't take my cranks anywhere else than to Frank but Darwin and Blacktown are a long way from Melbourne anyway so neither of us are helping Curtis with his need. I've never heard of the fella in Darwin but I have no doubt he's fine. It's just such a long way to send something that can be done locally.......that's my point.
Offline D project
« Reply #5 on: September 11, 2013, 12:58:19 pm »
Try ken Colvin over in Heidelberg.
He one of the old school boys.
Likes to have a chat so you need to keep at him to get it done ;)
Offline topari
« Reply #6 on: September 11, 2013, 02:28:54 pm »
Dare I ask what a crank rebuild involves ?
topari
1979 IT400F, 1984 kdx200
Offline Viper666
    • Ballarat Rovers MCC
« Reply #7 on: September 11, 2013, 03:50:12 pm »
PM Stan S
« Reply #8 on: September 11, 2013, 04:50:32 pm »
Not that much but several different methods with a million do's and don'ts. A few specialised tools you need and some dial inducators.
 Roughly you will check the crank for run out and most importantly the threaded end is straight and the centre point is intact. Scribe a few lines on it to reference, with your press plate inbetween the webs and supported press against the crankpin.
The crank is in half now, if you want to replace the crank pin here is the tricky bit, holding 1 crank web and putting a few tonnes onto the pin to get it out.
The next trick is to press the pin in at 90 deg to the web and parallel to the crank axis, I use a guide bush with the pin frozen and the web heated. Thrusts, rod and bearing are installed and then it's ready to go back together.
Most will have a jig or press tool to keep journals and webs in line again pin frozen web heated.
Then it's ready to true up, both axial and radial run out checked with dial indicators. Gently smacked with a copper/brass hammer and or squeezed in a vice.
Much better things to do on a saturday arvo  ;)
Putting the crank in a $15 express post bag and a self addressed satchel inside it with $50 will get your crank done in a week or so. That passes my test for help.
Offline Curtis
    • japspec.com.au
« Reply #9 on: September 14, 2013, 07:48:27 pm »
Thanks for the info guys! Ill suss out all these options and go from there.  :D
