Author Topic: For Sale RM125 1977  (Read 2195 times)
graham111
For Sale RM125 1977
« on: September 09, 2013, 11:06:47 pm »
RM125 on EBay
Ends 15th Sep 2013  http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=161101113715
I bought this RM 125 when I was in school. It wasn't running when I bought it and I fixed it up as a project after school.
It just needed a coil and a service.
Great first bike or even race in vintage motocross.
Pickup is in Springwood NSW 2776.
It has new bars, front mud guard, front race plate, air filter, new kick start.
Just had a service, new plug, new fuel filter hose and oil.
I have never raced it in the seven years I have owned it, just rode it around my property.
Everything is clean and it has been well looked after.
Starts first kick.
Tires don't have a lot left on them.
Parts the bike also comes with.
Muffler baffle,  NOS bearing suz-09262-22029, NOS fork seal kit, kick start, pei magneto, 1 x 09283-25066, 1 x 09289-30003, clutch and brake leavers, air cleaner oil, kick start and the service, repair and maintenance manual.
Video of it running.
http://youtu.be/abvhBNgWIs0
RM 125 1977
Overall Length: 2,060 mm (81.1 in)
Overall Width: 840 mm (33.1 in)
Overall Height: 1,120 mm (44.1 in)
Ground Clearance: 300 mm (11.8 in)
Wheelbase: 1,405 mm (55.3 in)
Dry Weight: 88 kg (194 lbs)
Engine type: Air-cooled 124,8 cc single-cylinder 2-stroke eed valve. 26.5 hp/ 10,750 rpm, 1.82 kg-m/ 9,500 rpm.
1977 RM125B specifications (International)
Engine type: Air-cooled single cylinder two-stroke
Cylinder displacement: 123 cc (7.5 cu-in.)
Intake system: Suzuki Power Reed
Bore x stroke: 54.0 x 54.0 mm (2.13 x 2.13 in.)
Compression ratio: 8.0 :1
Carburetor: Mikuni VM32SS
Air cleaner: Polyurethane foam element
Clutch: Wet multi-pkate type
Transmission: 6-speed constant mesh
Gearshift pattern: 1-down, 5-up
Starter system: Primary kick
Final drive: Chain
Ignition: Suzuki PEI (Pointless Electric Ignition)
Front suspension: Telescopic, pneumatic / coil spring, oil dampened
Front suspension stroke: 230 mm (9.1 in.)
Rear suspension: Swinging arm, gas / oil dampened
Rear suspension travel: 224 mm (8.8 in.)
Front brake: Drum brake
Rear brake: Drum brake
Front tyre dimension: 3.00-21 4PR
Rear tyre dimension: 4.10-18 4PR
Fuel tank capacity: 6.0 liter incl.reserve (1.6 US gal, 1.3 Imp gal)
Color: Yellow
Feel free to call me with any questions on 0422963013. Graham.
Don't ask for me to take it off EBay.
