Author Topic: Annealing copper head Gasket  (Read 11431 times)
Offline oldyzman
  • 250 two stroke!
« on: September 08, 2013, 05:09:18 pm »
What temp Celcius to i heat up a copper head gasket to to anneal it
Brett
Offline Canam370
Re: Annealing copper head Gasket
« Reply #1 on: September 08, 2013, 05:15:36 pm »
I use a torch and heat the copper until it goes a nice pinkish/rainbow colour. Once it cools the pink fades but that should be enough. Works for me!
Offline brent j
« Reply #2 on: September 08, 2013, 05:52:33 pm »
Heat it red hot and drop it into cold water
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: September 08, 2013, 08:01:23 pm »
BS Brent, that would harden it
Offline Paul552
  • HEAVEN #552
« Reply #4 on: September 08, 2013, 08:08:55 pm »
Not copper it won't
« Reply #5 on: September 08, 2013, 08:12:00 pm »
The first time I tried it was when BHP taught me and hundreds of times since.
As Brent said, cherry, glowing red. Then drop it straight into your prepared cold water.
Very important that your water is mixed with one cup of metho to five cups of distilled water.
They then come out spotless, free of scale etc.
Distilled water is not essential but it's dirt cheap and produces a gasket free of soot and scale. It will require no further cleaning.
« Last Edit: September 08, 2013, 09:02:01 pm by Mick D »
« Reply #6 on: September 08, 2013, 08:18:14 pm »
Yep I follow the heat and rapid cool water/metho system as taught by an A grade mechanical engineer.
PS that system should not be used if trying to re-anneal your vintage wedding tackle....  ;)
« Reply #8 on: September 08, 2013, 08:31:36 pm »
Its possible you may be thinking of case hardening certain Irons and steels.
Mick.
Offline oldyzman
  • 250 two stroke!
« Reply #9 on: September 08, 2013, 08:54:15 pm »
Sorry Brent, i Just thought you were kidding.... Seems some others agree.
Thanks for all of your help
Brett
Offline oldyzman
  • 250 two stroke!
« Reply #10 on: September 08, 2013, 09:04:38 pm »
Good Video's also
Offline cumagutsa
« Reply #11 on: September 09, 2013, 08:58:22 am »
if you cool it off straight away or let it cool naturally makes zero difference.
Offline brent j
« Reply #12 on: September 09, 2013, 12:50:56 pm »
Brett
No worries Brett,
If I put a bit more detail in my post it would have been easier to follow
Brent
Offline David Lahey
« Reply #13 on: September 09, 2013, 02:03:34 pm »
I use cumagutsas method (just letting it cool in the air), because there is no risk of causing it to go out of shape, which can happen if quenched in water
previous pseudonym feetupfun
« Reply #14 on: September 09, 2013, 02:57:35 pm »
I've always heated then until they're a pinky red and dunked them straight into cold water, that's the way I was taught during the coppersmithing part of my apprenticeship. I've never had a gasket go out of shape that I can recall.
