Author Topic: RM 400 Rodkits  (Read 13642 times)
Offline Bruno1969
RM 400 Rodkits
« on: September 06, 2013, 06:22:46 pm »
Hi guys,
My 78 RM 400 broke its conrod - taking with it the brand new small end and piston naturally!.  Replacement rod kits (either NOS or aftermarket) are extremely difficult to come buy and pricey.
A few of us in South Africa have sourced a company which is willing to make up a supply but in order to make it feasible there must be a decent amount of interest. Likely sell price is between 150 and 170 Euros.
Anbody in Aus or NZ keen to to take a couple?
Re: RM 400 Rodkits
« Reply #1 on: September 06, 2013, 07:20:41 pm »
New Zealand people would source from here  ;)
mailto:[email protected]
Richie makes  KX and Rm rods
Re: RM 400 Rodkits
« Reply #2 on: September 06, 2013, 08:28:18 pm »
78 RM400C has the same rod as a RM370.....like you say....hard to find and expensive...$300 to $500 just for a rod....when you can find one.
Offline VMX Andrew
Re: RM 400 Rodkits
« Reply #3 on: September 06, 2013, 08:52:17 pm »
Is the 78 model brand a desirable mount.
Cut off for pre 78s are a major killer over here in OZ...
Big difference between Evo and 78s, except for the Maico frankenbikes.
Next on the wish list..
Offline Bruno1969
Re: RM 400 Rodkits
« Reply #4 on: September 09, 2013, 03:17:38 pm »
i didnt relaise that the 370 and 400 rods were the same! Learn something everyday!
Because of the way the classes are structured in South Africa, a 78 or 79 bike is quite desirable, fitting in, as it does, in the late part of the 75-79 group.
Re: RM 400 Rodkits
« Reply #5 on: September 09, 2013, 05:35:17 pm »
I will firmly commit to one, but most likely two, I will need to check the second engine first.
Thanks for your enthusiasm on a possible easy solution Bruno 8)
Re: RM 400 Rodkits
« Reply #6 on: September 09, 2013, 05:57:52 pm »
woops, hang on.
Mine requirements are RM400T
Are they the same ???
Re: RM 400 Rodkits
« Reply #7 on: September 09, 2013, 07:21:07 pm »
Same rod  ;)
Part # = 12161-40400
Part Description = ROD,CONNECTING
Model Count = 2
RM400N 1979 417 RM400 OFF ROAD
RM400T 1980 417 RM400 OFF ROAD
I'm pretty sure there is a person selling rods on the net  for Kx and Rm 400 ...... see if I can find it again.
Re: RM 400 Rodkits
« Reply #8 on: September 10, 2013, 05:56:17 am »
You're thinking Tri-mac machining in Auckland, sometimes lists on ebay & trademe
http://trimacmachining.com/gallery.html
Offline KTM47
Re: RM 400 Rodkits
« Reply #9 on: September 11, 2013, 03:16:36 pm »
Model Count = 2
I contacted Richie at Trimacmaching. They make rods for RM 400 N&Ts
The part No for the RM 370 rod is 12161-41200. The RM 400C rod is same as 370 A&B.
Does anyone know the difference and can the 400 N&T rod be used.
Kevin
MAICOS RULE DESPITE THE FOOLS
Offline bazza
Re: RM 400 Rodkits
« Reply #10 on: September 12, 2013, 04:30:18 pm »
is rm and pe rod the same?
saw some one advertising Seadoo rod for PE400
Embrace patina
Re: RM 400 Rodkits
« Reply #11 on: September 12, 2013, 05:07:25 pm »
Bazza  ....   Rm 400 and Pe 400 rods are not the same. And yes the Sea doo 650  1997 Rod  is the go with a few extra thrust washers each side  on a Pe 400 ;)
Re: RM 400 Rodkits
« Reply #12 on: September 12, 2013, 05:33:18 pm »
Kevvy, RM370/400C is unique to themselves....do you need one?
Re: RM 400 Rodkits
« Reply #13 on: September 12, 2013, 06:14:28 pm »
I will probably need one..
Offline KTM47
Re: RM 400 Rodkits
« Reply #14 on: September 13, 2013, 08:55:15 pm »
What I am asking, is the RM 370 A&B and RM 400 C rods the same and then are the N & T rods the same. Trimac-machining make a rod for the RM400 N&T.
I have found one on eBay but I have become a bit suss about it.
