Author Topic: Works replica, such a thing?  (Read 16910 times)
Re: Works replica, such a thing?
« Reply #15 on: September 06, 2013, 08:43:04 pm »
Nathan, Whats you opinion on the best Japanese late 80's 250
Brett
US-spec '89 KX250.
'87 CR250.
'88 KX250.
The Suzuki boys all rave about the '88 RM250, but they're properly rare.
The 88/89 CR would be good if you can get the forks right.
Offline 09.0
« Reply #16 on: September 06, 2013, 08:51:33 pm »
Brett
US-spec '89 KX250.
'87 CR250.
'88 KX250.
the 88 cr 250 forks would be good straight up being conventional.
Offline VMX Andrew
« Reply #17 on: September 06, 2013, 08:55:53 pm »
Believe it or not the 87 model forkin forks were better Brad.  ;D
Offline oldyzman
  • 250 two stroke!
« Reply #18 on: September 06, 2013, 09:19:09 pm »
SO does the 87 cr suffer from water pump housing corrosion issues like the 83 etc...
Brett
« Reply #19 on: September 06, 2013, 10:51:44 pm »
Yep. I believe there's a later aluminium clutch cover that fits, unlike the '84s.
Honda messed up the 88 CR250/500 forks. They were a step behind the 87 forks, although I'm not sure if the solution is as easy as springs and valving, or not.
There was also criticism of the rear suspension. Probably because that was the start of Honda's idiocy of super-soft springs and too stiff compression valving.
Offline Scootern29
« Reply #20 on: September 07, 2013, 02:18:20 am »
If it started life at Arizona Mikes I'd be a bit wary. Got any photos?
Thanks Firko, I spit coffee all over myself
« Reply #21 on: September 07, 2013, 10:09:59 am »
Water pump, only true for 500's, 250's went to ali in '92 but also used a different PV set up.
All the other words you speak are true...
.....except for that sex max crap ;)
Offline oldyzman
  • 250 two stroke!
« Reply #22 on: September 08, 2013, 04:45:00 pm »
So EVO550, you are saying that the 87 250 still had bad water pump housing material. but from 92 was all OK? See i am buying a pre 90 very soon for Dirt track, as my 83 left foot kicker kills me? and i want disc brake too.
Brett
« Reply #23 on: September 08, 2013, 07:14:09 pm »
Brett
Yep, sorry.
Not interchangeable either.
« Last Edit: September 08, 2013, 07:20:56 pm by evo550 »
Offline davidmc
« Reply #24 on: September 08, 2013, 09:15:08 pm »
1985 KX Range had preload adjusters on the forks and Ride height adjustment on the Rear Upright linkage as well as previous mentioned items on this thread, they had a lot of features from previous works Bikes and were a true works replica as such.
They worked very well and were ahead of their competetion.
Offline Tahitian_Red
  • Mugen ME480
« Reply #25 on: September 09, 2013, 02:20:37 am »
Most of the Euro bikes were "Works Replicas" from the previous year (Minus hand built pipes and all the titanium)
 ;D
The "Factory Novice"
California, USA
Offline 09.0
« Reply #26 on: September 09, 2013, 05:35:41 am »
Having both an 85 cr500 and an 86 kx500, when comparing both I prefer the cr with no power valve, drum brake rear etc.
But again when there is no comparison such as yesterday I was comfortable on the kx and had a good days racing. It did everything well. It sure is a pretty thing.
Offline 09.0
« Reply #27 on: September 10, 2013, 07:55:16 pm »
Before the weekends outing.
« Reply #28 on: September 10, 2013, 08:37:44 pm »
If it works and it's a replica....then..... :-X
