Author Topic: Biggest Bighorn  (Read 9750 times)
Offline EML
Biggest Bighorn
« on: September 05, 2013, 12:14:26 pm »
What is the biggest Bighorn anyone has seen.....can they be built into a 400 or bigger and what sort of HP do they/can they make?
Re: Biggest Bighorn
« Reply #1 on: September 05, 2013, 01:31:22 pm »
Think there was a 'evaluation' 400 big horn in the US there is a pic floating round on the net, looks just like a 350 believe it or not. Don't think it ever went into production.
HP will depend on the fuel you use and what you use it for, but 50 disc valve HP is easy done. He doesn't ride it much since he got his TZ750's but Dave Crussell from the US   had 51hp at the wheel from his Scott Clough tuned Big Horn road racer. Was still a mild state of tune.
I'll have to pull a crank out and have look to see if they could be stroked the cylinder can go out a bit so 370-380cc might be do-able.
Offline EML
Re: Biggest Bighorn
« Reply #2 on: September 05, 2013, 01:34:21 pm »
Thanks Lozza, what size carb do they run behind the rotary disc and can it be enlargend ( is that even a word??)
Offline paco
Re: Biggest Bighorn
« Reply #3 on: September 05, 2013, 03:32:36 pm »
No! the proper word is embiggened.p
what ! Who me ? Nah
Offline farmer58za
Re: Biggest Bighorn
« Reply #4 on: September 05, 2013, 05:12:49 pm »
http://twostroke.tripod.com/newhorn/index.htm
http://www.klemmvintage.com/Bighorn-Bison-recreational.htm
There's a start. If you PM me with an email, I'll send the factory speed kit spec's.
Regards
David
Dave's not here man
Offline EML
Re: Biggest Bighorn
« Reply #5 on: September 05, 2013, 07:02:23 pm »
Thanks farmer ,already found the Klemmvintage thing. Sounds like they might be a goer. ;)
Re: Biggest Bighorn
« Reply #6 on: September 05, 2013, 09:58:35 pm »
The carb is in front of the disc and no you can't really embiggened the disc  (it's not a word either but probably should be  :D) What to get right is the timing of the disc. What's this for? Largest carb you could get with a modified disc cover would be a 40/44mm Mikuni.
« Last Edit: September 05, 2013, 10:05:04 pm by Lozza »
Re:
« Reply #7 on: September 05, 2013, 10:30:08 pm »
and could it be enlarged  ;)    or maybe humongously embiggended .
Biggest Bighorn? perhaps half a dozen Viagra tabs in the fuel mix...... :-*
« Last Edit: September 05, 2013, 10:32:10 pm by Tim754 »
Offline EML
Re: Biggest Bighorn
« Reply #8 on: September 06, 2013, 08:48:18 am »
May tag name is EML and you ask what it's for?? Com'on Purple Dave has cornered the SC500 market so we need to broaden the range.
350 Bighorn sound like it can make 50HP easy and will have abroad band. Perfect for trikes.
I understand the carby is before the disc and now read that bigger carbs can be fitted but it's better to move the disc(port timing)
It really sounds like someone shoulda done this a while ago and I don't normally do green...but who knows.
Offline EML
Re: Biggest Bighorn
« Reply #9 on: September 06, 2013, 11:33:15 am »
A well ridden lightweight of any description will always beat a dinosaur of any description.
Re: Biggest Bighorn
« Reply #10 on: September 06, 2013, 02:01:21 pm »
Yes I had ask if you said anything other than a sidecar,then I would have known that labotomy's are reversable  :D :D :D.
Port timing and disc timing are not intertwined as much as they are on other two strokes. All sorts of sneaky things we can do these days  ;)
http://youtu.be/ifSEql1X4R0
With a very average pipe and cylinder.
Re: Biggest Bighorn
« Reply #11 on: September 07, 2013, 07:07:38 am »
There's a 3 page article on Neil & his bike in the September Kiwirider magazine, didn't realize it was now running efi.
Wasn't he running a period hillborn? or similar setup a couple of years ago when it holed the piston playing in the maize paddock at whakatane?
Re: Biggest Bighorn
« Reply #12 on: September 07, 2013, 11:45:49 am »
They are out there just have to get them before the 'spliter-upper-ers' get to them and list every single circlip on ebay  ;)
