Author Topic: Yz400d dip stick  (Read 10222 times)
Offline Big Scotty
  • Heaven 380
Yz400d dip stick
« on: September 03, 2013, 06:12:13 pm »
G'day
Could somebody tell me the correct length my dipstick should be,mine measures 145mm from under the top to the end.mine seems to hit the bottom of the case when screwed in,any help appreciated
Thanks scotty
yz400d yz125d yz490k
Offline mick25
  • Hunter valley NSW
Re: Yz400d dip stick
« Reply #1 on: September 03, 2013, 06:19:17 pm »
Wish I had that prob with a dip stick to long  ;D ;D ;D sorry couldn't help me self :o
Offline Ted
« Reply #2 on: September 03, 2013, 06:34:35 pm »
What are you doing Scott, spring cleaning these bikes ;D
81 YZ 465 H   77 RM 125 B
Offline Big Scotty
  • Heaven 380
« Reply #3 on: September 03, 2013, 07:05:05 pm »
I was just down the shed polishing it ted  ;D ;D  we've all polished our dipstick at some time,thanks mick,new somebody would drag this post into the gutter,were do ya think the BIG scotty came from ;D ;D ;D
Offline hagon_84
« Reply #4 on: September 03, 2013, 08:37:02 pm »
Can tell ya tomoz arv when I get home but someone else on here probs owns one they can tell ya before then lol if not u will no tomoz ;)
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Simo63
« Reply #5 on: September 03, 2013, 09:48:30 pm »
Just measured mine and its exactly 140mm from the bottom of the dipstick to the base that sits on the rubber o-ring in the side cover.
But you just make sure you have 1100mm in them and away you go  ;)
Offline Big Scotty
  • Heaven 380
« Reply #6 on: September 04, 2013, 06:11:05 pm »
G'day
Thanks for measuring that,looks like yours is nearly as long as mine,they don't give a very accurate reading,might drain and refill then mark correct level,prefer the oil level screw in the side of the casing. Had a problem with my modern ktm (keep takin money)drained all the oil through the crank seal,don't want a bill like that again  ;D
Offline Ted
« Reply #7 on: September 04, 2013, 06:47:16 pm »
Scott, I and plenty others use ATF and dump it after every ride
Just pour in the recommended amount
It's cheap and it's what we used when these bikes were in their heyday
No measuring No worries chuck the dipstick
Offline Big Scotty
  • Heaven 380
« Reply #8 on: September 04, 2013, 07:55:04 pm »
Tried the automatic transmission fluid years ago ted,dam thing wouldn't  idle in gear or shift out of first gear by its self,went back to manual oil,works fine  ;D ;D
Simo63
« Reply #9 on: September 04, 2013, 08:30:28 pm »
Exactly what I do .. never had a problem
Offline SON
« Reply #10 on: September 05, 2013, 03:41:41 am »
Clean your fibres, lightly bead blast your steels and use MOTUL Transoil
ATF is OK
Transoil is better
Offline Ted
« Reply #11 on: September 05, 2013, 04:49:36 pm »
What's a liter of Motul transoil sell for?
Offline hagon_84
« Reply #12 on: September 05, 2013, 09:44:07 pm »
I use transoil expert and its rrp is 21 dollars a liter at most shops cheaper by the 4L bottle
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #13 on: September 05, 2013, 10:32:49 pm »
That would add at least another $42 to each race day budget for most. ATF is on the money  ;)
Offline Ted
« Reply #14 on: September 06, 2013, 08:45:43 am »
Exactly Rookie  I don't know why ATF doesnt get the recognition it deserves It has proven itself for the last 40 years  Its just oil without the hype
