Author Topic: montesa 172 cota  (Read 6970 times)
Offline paco
montesa 172 cota
« on: August 29, 2013, 10:00:41 am »
G'day everyone,  I am having a problem with the cota . When I go to start the bike I flood the carby with the tickler ,it starts easily and runs for awhile { about 5 minutes ] and then stops . It seems as though it only runs untill the carby bowl is empty. Any ideas as to what could be wrong.p
what ! Who me ? Nah
Offline TooFastTim
Re: montesa 172 cota
« Reply #1 on: August 29, 2013, 10:52:40 am »
Have you removed the float bowl to see if it is empty?
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #2 on: August 29, 2013, 02:15:23 pm »
After checking the float bowl, check to make sure the tank vent is not clogged. Should be able to blow air thru it.
Offline BULTACOBRIS
« Reply #3 on: August 30, 2013, 09:34:21 am »
Does it rev it's guts out before it stops? How much smoke?
Montynut
« Reply #4 on: August 30, 2013, 09:43:30 am »
Ignition condenser? once it gets a little warm it stops then cools down and restarts. Common if the condenser is still located under the flywheel and has been sitting for years.
Offline paco
« Reply #5 on: August 31, 2013, 05:31:22 pm »
Thanks for your answers . I hurt my leg riding my pursang so kick starting is out for awhile . It did blow smoke . It could be the condenser ; I will have a look at it when I'm feeling better.p
what ! Who me ? Nah
Offline BULTACOBRIS
« Reply #6 on: August 31, 2013, 10:19:12 pm »
If it's running out of fuel it will rev up hard before it stops.
If it just dies - Check the plug (oiled up) and for spark straight after it stops -  condenser usually play up when they get hot - a holden Gemini one can be used.
Has it been sitting unused for a long time?
« Last Edit: August 31, 2013, 10:23:01 pm by BULTACOBRIS »
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #7 on: September 01, 2013, 02:56:01 am »
You could not mount a condensor in a worst spot! Extreme heat and vibration will make them fail in no time. Disable the stock unit on the backing plate. Purchase any good automotive condensor with a ground wire. Mount the new unit under the tank or in the open (I use a small hose clamp on the frame backbone) run the ground wire to the coil mounting bolt. Splice the condensor's main wire into the hot wire coming out of the coil. Thats it, no more burned points!
Offline TooFastTim
« Reply #8 on: September 05, 2013, 08:42:23 pm »
Hey Paco, let us know when you have another go.
Offline paco
« Reply #9 on: September 06, 2013, 05:24:51 am »
Will do.Still waiting for the bone to knit in my leg.However I think it could be electrical because when I spin the back wheel in gear there doesn't seem to be any spark.p
what ! Who me ? Nah
Offline euro bikes
« Reply #10 on: September 06, 2013, 07:22:44 am »
I remember kicking my MK7 over at Tivioli in 74 it kicked back leaving a big hole in my leathers and me behind my knee ,6 stichers fixed it.
Offline paco
« Reply #11 on: September 06, 2013, 07:35:54 am »
Sounds painful;Euro
what ! Who me ? Nah
