Author Topic: TS250 rear rim width?  (Read 1758 times)
Offline ninjamk
« on: August 27, 2013, 02:11:24 pm »
Hi all, could someone please tell me the width of the rear rim for a 72 TS250? I am preping the bike to run in a hill climb and am trying to figure out my tire options.  The markings on the rim look like it says 18x185B so I would think it is a 1.85in rim?  The outer width is almost the same as a 2.15in rim I have from a RM so I just want to be sure.  Also if anyone has some common tire sizes that fit or a tire suggestion I would be happy to hear them.  I was looking at some 110-18 tires but am worried they may be too wide for a 1.85in rim.
Thanks!
« Last Edit: August 27, 2013, 03:06:50 pm by ninjamk »
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Re: TS250 rear rim width?
« Reply #1 on: August 28, 2013, 07:17:10 pm »
Yes the early models came with 1.85 alloy rims while others had Steel 2.15  ::)
« Reply #2 on: August 28, 2013, 07:58:39 pm »
should fit ok, check the swingarm clearance..ol mate had a early ts and im sure he had 100 (4.00 inch) knobby on it with no dramas, should sneak a 110 in ok.
