Author Topic: Fork oil height for '84 KX125C1 forks?  (Read 3100 times)
« on: August 27, 2013, 02:09:59 pm »
Would anyone have the fork oil height for an '84 KX125 ?
Offline Grunter215
Re: Fork oil height for '84 KX125C1 forks?
« Reply #1 on: August 27, 2013, 03:12:59 pm »
Hey John.  book says...602-610 cc....oil level 178-182 mm( 7 inch )
« Reply #2 on: August 27, 2013, 03:41:27 pm »
Thanks, wow that's seems pretty low?
« Reply #3 on: August 27, 2013, 09:30:07 pm »
Race Tech website says 135mm, I'll try both  :-)
« Reply #4 on: August 27, 2013, 09:59:14 pm »
130mm is a good setting for any Evo, pre 85, pre 90 conventional forks. The std settings in the manual are not necessarily the best settings, bit like std jetting..
« Reply #5 on: August 28, 2013, 08:18:39 am »
+1. I generally start with 150, but usually end up with more.
Also, the stock springs are ridiculously soft. 0.27s or something - literally the right rate for a 0kg rider...  :o
So that's well worth fixing.
« Reply #6 on: August 28, 2013, 09:35:46 am »
Thanks Guy's.  Yeh Nath the stock spring are suppose to run with air, I ordered a set of .46 springs from Walter yesterday.
