Author Topic: Ya 400 d fork oil  (Read 2429 times)
Offline hagon_84
Ya 400 d fork oil
« on: August 24, 2013, 08:12:04 pm »
Just wondering if anyone has a manual handy and can tell us how much fork oil to put in from empty on my 1977 yz 400d
Cheers Al.
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Offline mick25
  • Hunter valley NSW
Re: Ya 400 d fork oil
« Reply #1 on: August 24, 2013, 09:02:12 pm »
338cc oil    15w      182.5mm down from top with springs out and forks full compressed.
« Reply #2 on: August 24, 2013, 10:17:01 pm »
I run it about 140mm from the top down keeps the fork a little higher when you let the brake off and stiffens it up a bit.
Offline hagon_84
« Reply #3 on: August 24, 2013, 10:32:36 pm »
No  worries cheers for the info I was goin to run it bout 150mm down springs out fully bottomed out so pretty close to the money I guess ill be trying it in the mornin so ill see how they feel then
Offline hagon_84
« Reply #4 on: August 27, 2013, 11:35:12 pm »
Couldn't get any 15 wt oil got some 10wt from shop still feel bit springy no real dampening feel to them even taken out to 140 mm down from top, just wondering if u can run a few psi in them or if I should just drain them out and chase up some 15 wt fork oil to put in them
Cheers AL.
Offline PEZBerq
  • Brisbane
« Reply #5 on: August 28, 2013, 07:18:38 am »
As I understand it if you want more damping you will need to go to heavier oil. Oil level effects spring rate as the forks compress and the trapped air acts as a spring. Level does not control damping. Cheers
