Author Topic: 1983 Husqvarna 250WR headlight glass  (Read 2846 times)
Offline Ozadvntr
« on: August 22, 2013, 08:22:29 pm »
Headlight has been smashed and I want to keep the original assy. Any help or advice on an alternate, please contact me.
Mick
Offline PEZBerq
  • Brisbane
Re: 1983 Husqvarna 250WR headlight glass
« Reply #1 on: August 22, 2013, 09:03:01 pm »
You can fit a normal light unit from Autobahn etc and run a regular halogen lamp. It won't have the 3 lugs for bolting it in place but you can silicone it in place quite successfully. Alternatively you can cut the back out of the reflector from your smashed lamp so it is just a ring with the lugs. Carefully break out all the glass then use the ring to hold in your aftermarket light unit. I have done both successfully and you would never know from a casual glance at the bike. Can send photos if you want. You see lamps or entire headlight assemblies on eBay from time to time also if you want to stay strictly original.
Offline b490
« Reply #2 on: August 22, 2013, 10:13:38 pm »
This is my '83 headlight  assy .
   I used UFO  105 mm (plastic lens ) unit   to suit my    '83 ( D.C repl)   headlight housing .
   '84 & up  Husky   use different housing to '83  & have  LARGER   light ..,.so be sure what housing you have ....  &  be sure to measure  first.
   I had to make up 3 small mount tabs to secure lens assy   using the  3 screws , (as seen in pic)  ,
     to housing ( as per original look )
   UFO   Part No    ME 08076 ;   (105mm dia lens)
  Got it from this place  ;   (look in electrical  / ignition section)
http://www.enduroklassiker.at/artikel/index.php?mid=99
  ( NOS    glass h/ lights still can be found....... but you will pay plenty more for one.)
 Hope this helps
    Regards ,
                        Steve
« Last Edit: August 22, 2013, 11:30:31 pm by b490 »
