Author Topic: Honda CR250 and CR500 parts  (Read 2197 times)
Andy5151
« on: August 22, 2013, 01:53:30 pm »
Honda hubs, both disc models, the hub has a rear slight mod for running small sprocket on flange for rear one. Not sure of year model, but later.
Rad plastics CR250 maybe '89
Both very good condition.
$50 Hubs each. CR125/250/500
$20 rad deflectors
$10 rear disc cover '91
$40 CR500 muffler
Andy
0424169727
Sydney
Simo63
Re: Honda CR250 and CR500 parts
« Reply #1 on: August 22, 2013, 02:12:37 pm »
Hi Andy
I'm interestd in the radiator plastics if they are for an 89 CR250.  Any way you can confirm that?
Craig
Simo63
« Reply #2 on: August 22, 2013, 05:46:41 pm »
I measured my radiators, they are 105mm wide (between the mounting points, not including the little locating knobs) and approx. 250mm long.  If these guards are those dimensions then I'll take them thanks
« Last Edit: August 23, 2013, 08:08:41 am by Simo63 »
Offline Cooch 04
« Reply #3 on: August 22, 2013, 08:35:06 pm »
You don't have a front brake calliper lying around by any chance :-\
Simo63
« Reply #4 on: August 23, 2013, 08:09:05 am »
How did you go with the radiator guard measurements Andy?
Simo63
« Reply #5 on: August 23, 2013, 12:11:20 pm »
Will check and confirm the vertical mount centre measurement but sounds like they might fit.
