Author Topic: 1979 CR 250 Honda RZ brake pedal bushings.  (Read 1541 times)
« on: August 19, 2013, 01:00:34 pm »
I urgently need 2 Honda brake pedal bushings, part #46512-360-300 (Part #12 in the below diagram) to fit a '79 CR250 RZ or 1980 RA. I can probably get them from the USA but I need them by next weekend. Can new ones be sourced here in Oz or can someone supply me with a used pair?  Please :-*
Re: 1979 CR 250 Honda RZ brake pedal bushings.
« Reply #1 on: August 19, 2013, 01:11:20 pm »
Frank could knock them up for yeh in the lathe if you get stuck.
« Reply #2 on: August 19, 2013, 01:14:19 pm »
Apparently the bushings I need fits all Honda CR'S from '74-80 as seen in the list below...
« Reply #3 on: August 19, 2013, 01:23:13 pm »
Just get some made, it's way easier.
« Reply #4 on: August 19, 2013, 02:17:17 pm »
It's little thing like this that I miss being retired. I could have knocked 'em up out of Teflon in 10 minutes at work. I'll duck over to Franks tomorrow and get him to do 'em. I thought they might be a common old thing available at any Honda dealer but then I realised 1: Honda are hopeless and 2: there are no Honda dealers near here.
Offline oldyzman
  • 250 two stroke!
« Reply #5 on: August 19, 2013, 06:21:07 pm »
Try your local bearing supplier ask for a 2 x glacier bush with a flange. about $5 each, they worked on my 125RZ. NSW bearing supplies at fairfield will do it. They have a 1mm wall thick ness, you may have to trim them with a thin blade...
Brett
