Author Topic: coils  (Read 2102 times)
albrid-3
coils
« on: August 17, 2013, 04:47:14 pm »
how do you test a coil to see if its ok.
Offline oldyzman
  • 250 two stroke!
Re: coils
« Reply #1 on: August 17, 2013, 05:39:04 pm »
Use a multimeter on OHMS, most manuals will tell you the readings range you should get..
Brett
albrid-3
Re: coils
« Reply #2 on: August 17, 2013, 08:51:39 pm »
Thanks Brett, I have a coil that i don`t need its off a Dt1 68-69 model.
Offline oldyzman
  • 250 two stroke!
Re: coils
« Reply #3 on: August 17, 2013, 10:23:53 pm »
Do you have the specs for what it should read Between the high tension lead and the other input cable or cables. Dave?
albrid-3
Re: coils
« Reply #4 on: August 18, 2013, 04:02:41 pm »
No, Brett I have nothing.
Offline oldyzman
  • 250 two stroke!
Re: coils
« Reply #5 on: August 18, 2013, 04:55:02 pm »
OK Dave,
according to my info:
Secondary Measure between the Spark Plug lead and the earth (mount) should measure 6000 Ohms (6K Ohm
Primary Measure between the input cable and earth (mount) should measure 0.6 Ohms ie almost short circuit
Call me if you want
Cheers Brett
