Author Topic: Yamaha DT2MX clutch actuator rod length and bearing size.  (Read 3986 times)
« on: August 13, 2013, 10:00:13 pm »
I've got three different length clutch actuator rods and two different sized ball bearings. What's the correct length for the rod and OD of the ball bearing please?
Offline OverTheHill
Re: Yamaha DT2MX clutch actuator rod length and bearing size.
« Reply #1 on: August 14, 2013, 09:04:26 am »
tryin t think, long ago--mushroom clutch end is bigger than pushrod Firko & has a 5/16 ball between it & pushrod. Not sure of pushrod length but diameter is 1/4 by memory [6.5mm] & is a reasonable fit through the shaft so it sits pretty good against the 5/16 ball as it operates the clutch. In saying that--there's a 1/4 ball recessed into the lifter arm which sometimes gets out [on the bench] if the little punch marks wear off. for length i [if stuck for genuine bits like me] just fit it all up with a longer rod than necessary, sit lifter cover against it & measure the hap to shorten up & re-harden the end. I do a similar measuring trick when making throttle cables--solder end on lightly, fit it up, pull outer cable to seat everything, then measure the gap to the adjuster or carb top bit.
That should start the ball rolling & if my memory's up the creek hope someone puts me right. Cheers.
« Reply #2 on: August 14, 2013, 10:32:04 am »
Thanks Morley, the ball diameter was the main thing I needed. Because I'm using a Crockett and Son Racing Specialties YZ-A replica clutch actuator, the longest of the rids I've got seems to be one that'll make the final cut. I'll run down to the bearing place this afternoon and buy a handful of 5/16 or 8mm ball bearings.
Offline yamaico
« Reply #3 on: August 14, 2013, 11:49:58 pm »
Probably best you drive down Mark, what with those dicky knees and all...
Offline OverTheHill
« Reply #4 on: August 15, 2013, 09:14:53 am »
yamaha have a way of, listing things that help id sizes sometimes. have a look at yam parts through the link on our 'livewire vmx' site, go to links then down to yam parts & find your way to dt2mx. clutch mushroom ball shows a 5 at end of first numbers then a 16 as first two of second row which means 5/16 or [8mm], yam numbers can be quite helpful sometimes. Cheers. ps, i'm sure you knew all that Firko, so i won't pull the 'Mr Know It All' line haha.
« Reply #5 on: August 15, 2013, 09:26:33 am »
I didn't know that Morley and feel free to remain Mr Know-it-all mate, it's always good to learn new stuff.
« Reply #6 on: August 15, 2013, 09:41:53 am »
KTM are the same with p/n, if you know how to read them you can work out all sorts of things.
Offline GD66
« Reply #7 on: August 15, 2013, 09:59:32 am »
Morley spotted at a Gisborne beach race on his 250 Yamaha in 1973.
Looking good, son !  ;)
« Reply #8 on: August 15, 2013, 10:03:23 am »
Groovy sideburns Morley. 8)
Offline OverTheHill
« Reply #9 on: August 15, 2013, 08:47:43 pm »
god damn it, where do ya find these things. There's more hair on those sideburns than on my head now--thank for reminding me!!
