Author Topic: Yamaha sprockets  (Read 4480 times)
Offline steve7406
Yamaha sprockets
« on: August 12, 2013, 05:24:35 pm »
Rear sprockets for a 74 mx 250 where can you get them.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: Yamaha sprockets
« Reply #1 on: August 12, 2013, 07:48:49 pm »
I bought mine from John Titman.
I don't know of any "off the shelf" option.
Offline Andrew L
« Reply #2 on: August 12, 2013, 08:33:00 pm »
I think these are the same bolt pattern but only go up to 49 teeth they fit several other models as well search the site a bit more you might find what you need.
http://www.jtsprockets.com/catalogue/model/6330
« Reply #3 on: August 12, 2013, 09:27:59 pm »
I'm pretty sure the IT125 used the early YZ125-IT175 bolt pattern, which is different to the MX250 pattern.
If my memory serves me, the MX250/360 and SC500 are the only ones to use that particular sprocket.
« Reply #4 on: August 12, 2013, 10:47:06 pm »
Might be wrong , but I think DT2MX and RT2MX use it same as well . Iain
« Reply #5 on: August 13, 2013, 07:01:40 am »
PBI Australia.....  ;)
Offline steve7406
« Reply #6 on: August 14, 2013, 04:53:07 pm »
Thanks guys will ring PBI will also ring john titman again last phone call I made was told don't do em.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
« Reply #7 on: August 14, 2013, 06:36:37 pm »
You need to talk to John, they have blanks and a wall full of all types of sprockets which he can re-drill the center to suit. Titty keeps a "book" with all of the measurements in it...old school but it works. If he hasn't got it on file, send him your old one so he can copy it.
« Reply #8 on: August 14, 2013, 06:55:56 pm »
John makes them , only speak to John the others are good for more modern stuff but John is the brains with sprockets . He's made 2 or 3 for me over the years . Iain
« Reply #9 on: August 14, 2013, 08:00:46 pm »
I got some random young bloke when I rang (definitely not John) and had no hassles?!
« Reply #10 on: August 14, 2013, 08:01:56 pm »
PBI have them in stock    7054 -51
