Author Topic: 74 kx 450 parts $175  (Read 1445 times)
Offline MauriceR
« on: August 07, 2013, 02:50:12 am »
Sounds like a good deal but i know nothing about kx parts
http://seattle.craigslist.org/see/mcy/3971491531.html
1974 Kawasaki KX450 Parts Lot - $175 (West Seattle)
 Lot of parts I am 90% sure are off a vintage 74 KX 450 mx motocross bike. Includes a Swing arm with torque rod, cases with magneto and transmission (transmission spins, has output shaft sprocket still installed), foot pegs, clutch basket assembly, front & rear wheels with brakes (DID wheels) with 41 tooth sprocket, kick starter shaft / gear assembly with return spring, side cover, magneto flywheel, brake pedal, misc. other parts. I was told this came off a 74 and am pretty sure its the case (for example, the swing arm is the early non-reinforced version, different that whats on my 75 & 76's). What you see in the picture is what you get. Reply with your phone number. Will not split up as I need to sell in one shot due to time constraints. Thanks.
    it's NOT ok to contact this poster with services or other commercial interests
