Author Topic: YZ250-A ignition cover  (Read 7008 times)
« on: August 05, 2013, 12:49:52 pm »
It's probably so obvious that I can't see it ??? but what's the difference between a DT1, DT2 and YZ-A/B ignition covers other than the raised lettering on the very first DT1 version?
Offline Tahitian_Red
  • Mugen ME480
Re: YZ250-A ignition cover
« Reply #1 on: August 05, 2013, 02:20:32 pm »
One word: Magnesium.
At least that's what I read somewhere.  I already picked up an aluminum ignition cover, but I'm still on the hunt for a Clutch cover.  ;D
The "Factory Novice"
California, USA
« Reply #2 on: August 05, 2013, 02:30:27 pm »
I wonder how many YZ-A's still have the original mag cover? I'll have to go through my ignition cover stash because I've got one that seemed noticeably lighter but didn't think much of it at the time. Out come the scales....again ;D
« Reply #3 on: August 05, 2013, 02:51:07 pm »
Only the B has magnesium clutch and ign covers.....the A's are alloy. Another point is the B ign actually sits about 10 mm higher because it has the later type coils....the inside of all those covers are totally different. You know you should ask the cripple Firko.
« Reply #4 on: August 05, 2013, 03:29:02 pm »
So, you decrepit old goober ;D....Are you telling me that the DT2 and YZ-A covers are externally the same, overlooking different casting marks inside? Another question.....is the YZ250-A barrel stud spacing the same as a DT1? I know the 360's have different rear spacing but wasn't sure of the 250's. I just bought a YZ250-A barrel so I can now use my YZA transmission and clutch and clutch cover in a set of DT1 cases and build a poor boy YZ motor for my little spare Hindall. Ah sweet joy. ;D
« Last Edit: August 05, 2013, 04:06:26 pm by firko »
« Reply #5 on: August 05, 2013, 04:56:45 pm »
The barrel will fit old timer.
« Reply #6 on: August 05, 2013, 05:28:04 pm »
With the knowledge I have now I would love to know how hard a YZ A 250 would run with the right reeds and cage and a well tuned 38mm Bing PVL ignition,more compression,  except I probably know its about 3 moto's before the dogs wear off 5th gear running that setup.
« Last Edit: August 05, 2013, 05:33:08 pm by Slakewell »
« Reply #7 on: August 05, 2013, 05:52:06 pm »
Some of the early covers DT1 have only two mounting holes . Iain
Offline KB171
« Reply #8 on: August 05, 2013, 06:21:28 pm »
This'd be a YZ 250 B cover.
« Reply #9 on: August 05, 2013, 10:21:46 pm »
I've got a YZ250-A transmission in my methanol DT1 piston port engine that I got off a bloke who'd replaced them because the dogs were rooted. I undercut them myself with a die grinder, didn't bother re hardening them and the gearbox survived three solid years of thrashing in the DT1 from Hell...and you know the flogging that old beater copped Slakey. I had a look at the gears a couple of weeks ago and they're still in good usable condition, ready for new adventures ;D.
Thanks KB you saved me a lot of weighing......I haven't got one with Magnesium cast into it. I guess I've just got plain old DT1 stuff. Oh well, at least I've got the right YZ-A clutch cover and a sprocket cover from Joan Engineering.
« Last Edit: August 05, 2013, 10:28:43 pm by firko »
« Reply #10 on: August 06, 2013, 09:05:57 am »
The one good thing about evilbay is that those impossible to find parts are now accessable....there are plenty of YZA gears available an evilpay most of the time.The 250/360 A/B Y zed engines are works of art when you look inside one....no wonder Yamaha lost a fortune on them, but it sewed the seed for later models and perspective buyers.
« Reply #11 on: August 06, 2013, 10:08:30 am »
Well, the deal's done and the YZ-A barrel's on its way. What reed valves fit? Is there a V-Force kit to suit or do we adapt one from something else?
« Reply #12 on: August 06, 2013, 10:22:48 am »
V force fits, I'll get the p/n for you.
« Reply #13 on: August 19, 2013, 10:04:14 am »
This supposed YZ-B magnesium ignition cover is for sale on Marks Swapmeet this morning for a cheap $75 BUT it doesn't have "MAGNESIUM" cast into it like the one KB posted above. I'd like to buy this but don't want to get stuck with another DT1 cover so what's the story YZ-B Brains Trust?
« Reply #14 on: August 19, 2013, 10:09:59 am »
That's just a std alloy one Firko.
