Author Topic: Spark plugs  (Read 2487 times)
Offline steve7406
Spark plugs
« on: August 04, 2013, 02:54:51 pm »
Hi I've just been given some spark plugs NGK BR8EVX Platinum / NGK BMR4A anybody tell me what I can use them in.
Thanks.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline Speed
Re: Spark plugs
« Reply #1 on: August 05, 2013, 08:43:46 pm »
The BMR4A are the same as Champion CJ8 so they will fit Victor mowers and early BS and many chainsaws and more.
and the BR8EVX can be used where you would use a NGK B8EV, B8EGV or NGK BR8EV.
Hope this was some help.  I'm not 100% sure about the resistor plugs.  I believe the internal resistor is there to suppress ignition noise and to help guard engine management systems
from interference that may cause damage to them.  So you should use resistor plugs when called for by the manufacturer but it's ok to use them when not called for.
Offline EML
Re: Spark plugs
« Reply #2 on: August 06, 2013, 09:50:51 am »
The front of the NGK book/catalogue lists all codes.
B= 14mm thread 20.8 hex
R= resistor type (notes as above in last post)
8= heat range (higher number=cooler plug)
E= thread length 19mm
VX= platinum type
Offline steve7406
Re: Spark plugs
« Reply #3 on: August 06, 2013, 04:55:02 pm »
Thanks guys that's what I needed to know now have plenty of plugs to keep my motors happy for a very long time
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
