Author Topic: carby T vent kit....fact or fiction?  (Read 5001 times)
« on: August 02, 2013, 03:38:02 pm »
I spotted this kit on eBay and it roused my curiosity as to whether it's a good thing or just another crock of technical bullshit . Anybody tried it?
http://www.ebay.com/itm/YAMAHA-YZ490-YZ-490-CARBURETOR-VENT-HOSES-CLAMP-KIT-AHRMA-VINTAGE-1982-1991-YZ-/290938732651?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item43bd4cc06b
                            "T" VENT SYSTEM NOTICEABLY IMPROVES THROTTLE RESPONSE THROUGH WHOOPS AND JUMP LANDINGS
CARB OVERFLOWS FREELY ELIMINATING VAPOR LOCK
(KEIHIN PWK CARB IS SHOWN FOR DISPLAY AND IS NOT INCLUDED)
FITS ALL 2 STROKE KEIHIN AND MIKUNI CARBS FROM 1973 THROUGH 1993
MX BONZ WURX CARB KIT The original better clamps and tubes and still the best First introduced in 1997 by MX BONZ the WURX CARB KIT has been imitated but never duplicated 85 Durometer shore A polyurethane tubing cut to proper length eliminates guesswork This hose is made in the USA and MX BONZ is proud to provide proof upon request and that the American Employee is supported whenever it outsources its raw polyurethane and plastic materials
Features both intake and air boot clamps  Clamps are supplied by ABA of Sweden a country deeply rooted in motocross tradition and are the hidden secret to the MX BONZ WURX CARB KIT These clamps eliminate all air leaks enabling the tuner to accurately jet the carburetor without a doubt
Kit includes heat shrink tubing to join the upper vent loop factory works style
USE THE PICTURES IN THE LISTING FOR CORRECT ASSEMBLY
KITS ARE SHIPPED UNASSEMBLED
USE A LIGHT GREASE ON THE "T" FITTINGS WHEN FITTING HOSES
WD-40 ON HOSES ENABLES THEM TO BE PULLED THROUGH RETAINER RINGS EASILY
TM BILL
Re: carby T vent kit....fact or fiction?
« Reply #1 on: August 02, 2013, 04:52:56 pm »
They do work Mark but you dont need the fancy kit you can just put a T piece in your original hoses and put your vent hoses above the float bowl. I dont think they are nessercery on vintage tracks , they do stop bogging on landings from big jumps .
Offline yamaico
« Reply #2 on: August 02, 2013, 09:18:26 pm »
I don't even "T" mine - just join the two up over the top and cut some small slices out of the side with the stanley knife. If you're interested Mark I can sell you the kit for only $199.99 + p&h. Just hit the "buy it now" button.
« Reply #3 on: August 03, 2013, 12:25:11 pm »
Dellorto carbs on trials bike use the same system as you describe  Pete but loop under the carb, seems to work except in deep water
Have a look at a modern Keihin PWK carb at some stage, they have vent hoses exiting straight up as well as sideways to loop down to the rear of the cases so the manufacturers must think there is something in it
« Last Edit: August 03, 2013, 12:50:15 pm by tony27 »
Offline Mike52
  • 81 KTM 125 LC
« Reply #4 on: August 03, 2013, 12:40:40 pm »
Just what I need , now I can do airials on my TS100. ;D
« Reply #5 on: August 03, 2013, 12:47:22 pm »
They're great for water crossings - stops the rapidly cooling air in the carb from sucking water up the vent hoses. I got stopped in a case-deep creek crossing that caused me some undue stress at the four day...
Never felt the need on an MX track. Then again, most modern carbs have the T-pieces effectively built in to the carb body.
« Last Edit: August 03, 2013, 12:49:44 pm by Nathan S »
« Reply #6 on: August 03, 2013, 12:50:14 pm »
Which reminds me.....I'll check on that TS90 cover for you Mike.......I'll report back a bit later after my visitors go.
« Last Edit: August 03, 2013, 01:02:13 pm by firko »
Offline Mike52
  • 81 KTM 125 LC
« Reply #7 on: August 03, 2013, 01:16:03 pm »
Check your pm,s Firko , Tim came good with a heap of stuff.
To stop water getting in the carb via hoses we used to loop them up over the carb and down the other side .
Seemed to work ok.
« Last Edit: August 03, 2013, 01:17:59 pm by Mike52 »
