Author Topic: MX 125 D model  (Read 21043 times)
Re: MX 125 D model
« Reply #45 on: August 06, 2013, 09:09:39 am »
Is your 34mm carb a Yamaha one, or generic? The Yammie ones are usually different shapes to the generic ones (spigot sizes, lengths, height relative to centre lines, etc).
A YZ125X intake manifold will solve that part of the problem, but not the airbox boot problem.
The MX-C carb is the same as YZ-C, so shouldn't be too hard to find.
The other thing to look for is a 32mm carb from a YZ-D/E/F (and maybe G?). 32 is a better size than 34, IMHO.
Offline Scootern29
Re: MX 125 D model
« Reply #46 on: August 06, 2013, 09:48:28 am »
Nathan,
Actually the MXC carb is not the same as the YZC. At least over here they aren't. The YZC carb is much bigger. I have both carbs. The MXC has a one year 30mm short body from the factory. Over here they are unobtainable. I just happend to have one at my brothers house from years ago that I didn't know I had. The parts fiche even shows the different part #'s. The MXC carb is a 565 and the YZC is a 537. I spent two months calling everyone you could think of and there are none to be found over here. One of the contacts owns to of the little buggers.
Re: MX 125 D model
« Reply #47 on: August 06, 2013, 09:52:18 pm »
Scootern29 the Yamaha bible lists the carb as VM30SC it also uses the same as the 73\74 mx250 carb VM30SC also the YZ100c ,IT 125 G\H ,DT3 250 73 . gives you a few more places to seek . The YZ125c  was a VM34SS  .  Nathan the D E F G used a VM32SS carb . Iain
« Last Edit: August 06, 2013, 09:56:28 pm by iainyz »
Re: MX 125 D model
« Reply #48 on: August 06, 2013, 10:15:54 pm »
YZ125C had 30mm carb, it was the 125X that had the 34.
Thanks for the clarification on the 125G. :)
Re: MX 125 D model
« Reply #49 on: August 06, 2013, 11:26:40 pm »
That's interesting Nathan Ive just checked my 125c owners book and its as you say but checking on my Yamaha stats book it has the VM34SS !!!!! . mmmm someone has made a cock up somewhere . Iain
Offline Scootern29
Re: MX 125 D model
« Reply #50 on: August 07, 2013, 05:08:32 am »
Thanks for the clarification guy's. It seems half the time the part#'s and other data just don't jive between reference materials. Thank heavens we aren't dicussing parts on CZ's.
