Author Topic: Not VMX, GSXR1000 Superbike  (Read 1155 times)
« on: July 23, 2013, 03:16:35 pm »
For sale, Suz GSXR1000K6, 2006 model.  second owner, not used in the last 2 years (that's why I'm selling it), engine is quite fresh.  $9,000.
* Yoshi cams & valve springs.
* Yoshi EM Pro ignition & wiring harness
* PTR cylinder head.
* Yoshimura head gasket (Hi compression)
* Balanced crank.
* Power shifter
* New Hi-volume fuel pump.
* Pipercross race aircleaner
* Full Titanium & carbon-fibre exhaust.
* Kitted clutch
* 520 chain conversion with full range of alloy rear sprockets.
* Carbon fibre instrument/fairing bracket.
* Brembo front brake mastercylinder
* Ohlins steering damper.
* 1.0kg fork springs
* Ohlins rear shock, 9.0kg spring.
* Woodcraft handlebars
* Woodcraft engine case savers.
* Race front brake lines.
* Folding tip brake & gear levers.
* Double bubble windscreen
* Light weight lithium ion battery.
* Anti surge fuel tank foam.
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
Re: Not VMX, GSXR1000 Superbike
« Reply #1 on: July 23, 2013, 03:25:40 pm »
Hey John, not that I'm keen but for those who are.....is this bike a road registerable bike or a purpose modified race bike only??
« Reply #2 on: July 23, 2013, 03:32:37 pm »
It's set-up as a race bike only but it could be registered if you sourced all the road stuff.
