Author Topic: TM Suzuki wheels.  (Read 2720 times)
TM Suzuki wheels.
« on: July 19, 2013, 10:58:18 pm »
 I had a '76 TS250 rear wheel in my TM/TS El Cheapo which is now going in my little TM flat tracker. I've been offered a TM400 rear wheel with good spokes for $20. I also have a chance on a TM250 rear wheel. So my question is....are TM250, TM400 and TS250 rear wheels the same?
Offline Doc
Re: TM Suzuki wheels.
« Reply #1 on: July 20, 2013, 08:46:39 am »
Firko, the hubs are the same, the rims are slightly different. Early (steel rim) hubs are the same also as are the TS400 rears
« Reply #2 on: July 23, 2013, 10:02:06 pm »
I knew that you'd know that I knew that you'd know the right answer ;D.......Grazi Doctore.
Offline Richo52
« Reply #3 on: August 02, 2013, 09:52:10 am »
      Hi Firko if one of your TM400/250 wheels is spare I need one for a TM 250 project Im doing cheers.Richard.
SOME BIKES AND CARS
« Reply #4 on: August 02, 2013, 10:22:33 am »
Sorry Richo, I've only got one TM wheel, the others are a TS wheel with steel rim and what I thought was a TM wheel turned out to be from a PE.
