Author Topic: clutch oil  (Read 4352 times)
Offline paco
clutch oil
« on: July 19, 2013, 12:00:58 pm »
G'day, just about to get the 172 Montesa cota running again the only thing now is what oil to put in the clutch / gear box.Hope some one can help . The book says 20 grade but I cant seem to find any one that sells it.p
what ! Who me ? Nah
Offline euro bikes
Re: clutch oil
« Reply #1 on: July 23, 2013, 02:50:48 am »
Are they separate if so, i run ATF the one for older cars for the clutch and gearbox oil is 20/50 motor oil for older cars as well. That is what i use in my Bultaco and it works fine.
Offline paco
Re: clutch oil
« Reply #2 on: July 23, 2013, 06:18:40 am »
Thanks for your reply Euro. The clutch and gear box are lubricated by the same oil .ie.The clutch and gear box are joined.What I realy need to know : Is what quantity ?.p
what ! Who me ? Nah
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: clutch oil
« Reply #3 on: July 23, 2013, 07:49:07 am »
A warning to all owners of Montesa's. Do not use ATF in a Montesa clutch. Pre 1984 models use all steel plates. ATF causes glazing of the plates
and ruins them. I have seen it on a number of clutches. The Cota 172 holds 30 1/2 ounces of fluid.
Offline paco
Re: clutch oil
« Reply #4 on: July 23, 2013, 08:53:28 am »
Thanks for that Cappra. I am going to use straight 30 grade . Any other suggestions ? p
what ! Who me ? Nah
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: clutch oil
« Reply #5 on: July 23, 2013, 02:59:07 pm »
Some owners use a modern two stroke gear oil with good results.
Offline paco
Re: clutch oil
« Reply #6 on: July 23, 2013, 05:29:25 pm »
I have just bought some modern two stroke gear box oil . Thank you for your help , Euro and Cappra.p
what ! Who me ? Nah
