Author Topic: TT500 tracker on flattrack.com  (Read 4104 times)
« on: July 17, 2013, 11:12:05 am »
This is a great buy considering the gear it's loaded with. Even though it's a de-raked stock frame instead of an aftermarket item, the stock frame works really well in these situations. It's located in geographically desirable California too. http://www.flattrack.com/index.php?option=com_kunena&view=topic&catid=11&id=178513&Itemid=0
My wife is looking to sell her XT500 based flattrack racer. It features a 580cc stroker motor with a TPR big valve head and Mikuni VM38.
 It is set up for a plug in starter. TX750 forks with gold valves and Grimeca brakes. It is a cut, stock frame with SR500 swing arm. This bike is solid and stone reliable. Spares available.
 Frame has 25.5 degree neck, late SR swingarm with 19” rear rim on TT500 drum, front brake Grimeca caliper on EBC rotor- good solid brakes. Motor has 90mm bore and 91mm Powroll stroker crank, 578cc total, SR head ported by TCR and matched to Mikuni VM38, Megacycle 251-80 cam, Jemco pipe and starter adaptor- very stout and reliable motor. 36mm TX750 forks with Cartridge Emulators and Durelle springs mounted in TT500 triples, Works shocks, bike sprung and valved for 220 lb rider- excellent suspension. This bike is well built and very solid and reliable
Bike is in Lodi, Ca. $2800 OBO ptoms68atgmail.com or 209-712-zero165
