Author Topic: Warning - not VMX KTM300exce 2008 Rev Limiter  (Read 1917 times)
Offline oldyzman
  • 250 two stroke!
« on: July 11, 2013, 08:36:48 pm »
Hello,
Can some advise if the std ignition system has as rev limiter? If so what effect is felt when it cuts in.
Brett
Re: Warning - not VMX KTM300exce 2008 Rev Limiter
« Reply #1 on: July 11, 2013, 09:04:38 pm »
I had a '08 250 and now a 2013 300 and race in moderns and have never come across a rev limiter yet.. I do third gear starts and the throttle is to the stops waiting for the gate to drop and it doesn't miss a beat.
Are you having troubles at high rpm?
IT400C
« Reply #2 on: July 12, 2013, 10:02:01 am »
Hello,
Brett
If you've got one of the harder powervalve springs in (yellow or green, but green especially) - it can feel like it's got a rev limiter kicking in I suppose.
I only tried the green spring once (hardest - powervalve stays closed longest), and my 250EXC would only get to what felt like 3/4 revs before it just stopped going any further..
Check which PV spring is in it.  I found I liked the Red spring with the longer standard muffler for general bush riding.  For me it gave the best combination of mid-range grunt and top end power when needed.
Tony
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: July 12, 2013, 11:45:57 am »
at about 3/4 it often does not want to go any higher, I bang it back a gear rev it out then change and its OK. I am using a sx muffler and always have cause i like the snappy hit and better note... comming off a road registered YZ250 2 stroke the 300 was too tame stock..
Brett
« Reply #4 on: July 12, 2013, 12:00:26 pm »
When I had my 300 years back I experimented with the power valve to see what it was achieving and whether it was actually working, I disconnected the push rod and zip tied it open
Result was a peaky engine with minimal bottom end
Then I zip tied it shut which killed the top end and it wouldn’t rev out properly.
It sounds to me like your power valve is stuck shut, I doubt it is a rev limiter problem
Offline oldyzman
  • 250 two stroke!
« Reply #5 on: July 12, 2013, 12:06:53 pm »
Yep maybe the PV is a bit sticky... Good point GMC.
Brett
