Author Topic: What class a hybrid.  (Read 2665 times)
Quicksilver
« on: May 18, 2008, 07:14:29 pm »
If using number of parts from different model bikes to build hybrid is it legal for pre 85 as long as very parts used if off bikes built prior to 1985?
Example. Suzuki 1977 twin shock frame, Honda 1981 41mm forks and twin pull drum brake hub, Yamaha 1980 model 500cc 4 stroke engine. Suzuki 1979/81 swingarm, Suzuki 1983 wheels.
Re: What class a hybrid.
« Reply #1 on: May 18, 2008, 07:18:28 pm »
The bike would be dated by the age of its newest major component, ie, 1980 Yamaha engine so it'd be legal for pre 85 and Evo I would assume.
Quicksilver
« Reply #2 on: May 18, 2008, 10:38:47 pm »
Firko....If XT500 engine remained unchanged 1976 though to 1981 would that allow the engine to used pre 78 class even if it has 1981 engine number?  Like the 1975 CR125 is allowed in pre 75 because it was same as earlier year? If that was the case I do have the option of using earlier wheels, forks and swingarm to make pre 78 legal. Has the engine number thing been tested or is their already a ruleing on this.
« Last Edit: May 18, 2008, 10:41:07 pm by Quicksilver »
« Reply #3 on: May 18, 2008, 10:45:50 pm »
Quicky you'd probably get away with pre 78 but the 41mm forks and twin leading brake would have to go.
« Reply #4 on: May 18, 2008, 11:31:13 pm »
the engine did change the 1981 has bigger inlet valves than the 1978.my 1976 tt500 motor has a big fin 1978 sr500 head with the biger valves.but check with others it might be ok
