Author Topic: Cr250re disk side front wheel spacer?  (Read 1497 times)
Offline Paul552
  • HEAVEN #552
« on: July 06, 2013, 05:03:11 pm »
While fitting some nice fork boots I realized that my front wheel is off center??
Looks like it is about 5>7mm???? Too close on disk side.
At some point in time I think the spacer has been swapped lost or similar?
Anyway if anyone has one they can measure I am interested in how long it is?
The only other thing I can come up with is that maybe the front wheel bearings are thinner than standard ?
Either way I have to turn up a spacer.
Can anyone else think of a reason why ????
Or confirm the standard length
Offline Big Scotty
  • Heaven 380
Re: Cr250re disk side front wheel spacer?
« Reply #1 on: July 06, 2013, 05:24:52 pm »
G'day Paul
Has it had a new rim put on it,they may have not got the offset correct when it was respoked
Scotty
yz400d yz125d yz490k
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: July 06, 2013, 05:43:53 pm »
Consider how the disc lines up with the side float of the caliper..
Brett
