Author Topic: yz400e Jetting  (Read 5271 times)
Offline jake57
yz400e Jetting
« on: June 23, 2013, 12:29:52 pm »
now i can start the f&^%$#@g thing i have a problem with the jetting.
it has standard jetting
38mm Mikuni
main 370
Needle jet Q-0
pilot 60
needle 6f-16
standard pipe
DG silencer
i had this problem before i changed electrics
once started it will idle , it will not rev , turn the fuel off when it starts to run out it revs ok
thanks jake
Offline motomaniac
Re: yz400e Jetting
« Reply #1 on: June 23, 2013, 12:54:28 pm »
check the float level.
Offline oldyzman
  • 250 two stroke!
Re: yz400e Jetting
« Reply #2 on: June 23, 2013, 01:23:04 pm »
Yep like moto said, Check your float level, or check the needle for excessive wear...
Offline ARN
Re: yz400e Jetting
« Reply #3 on: June 23, 2013, 02:59:59 pm »
if float level is ok as it isn't running out of over flows ,they are miles to rich standard ,try 50 pilot I am running 45 and 3 plus slide (you can file yours) try that
Re: yz400e Jetting
« Reply #4 on: June 23, 2013, 03:33:08 pm »
also check/replace the needle jet coz they DO wear out
Offline jake57
Re: yz400e Jetting
« Reply #5 on: June 23, 2013, 03:40:55 pm »
thanks
new carbi , jets &needle
float level ok
3 slide
tried 45 pilot still the same
Re: yz400e Jetting
« Reply #6 on: June 23, 2013, 03:56:53 pm »
Don't tell me it's still giving you shit Jake? Has Phippsy had a look at it?
Re: yz400e Jetting
« Reply #7 on: June 23, 2013, 04:44:11 pm »
ok the jetting you have stated is it std yz400e jetting or what came with a 38mm off the shelf carb?
know anyone with a good running 400d/e?maybe borrow their carb to see if it cleans up your carb problems then copy it if it works ;)
Offline jake57
Re: yz400e Jetting
« Reply #8 on: June 23, 2013, 05:07:42 pm »
matt it is standard yz jetting
firko yes it is still playing up,no phippsy has not looked at it
Offline ARN
Re: yz400e Jetting
« Reply #9 on: June 23, 2013, 06:17:59 pm »
local bike shop had a yz250d which wouldn't rev out they rebuilt it and still had problem ,he lent a set of electrics of mine still no good ended up being a blocked exhaust or muffler.
Re: yz400e Jetting
« Reply #10 on: June 23, 2013, 07:56:14 pm »
How old is the needle jet?  Had the same problem with my KX, it was a worn needle jet.
Offline motomaniac
Re: yz400e Jetting
« Reply #11 on: June 23, 2013, 08:07:50 pm »
if you have the old carb try that.the new carbs are different and you will need to play around with the jetting ie original jetting spec wont necessarily work in a new mikuni.
Offline jake57
Re: yz400e Jetting
« Reply #12 on: June 23, 2013, 09:17:12 pm »
ARN  i will check pipe & muffler
John  needle jet is new
moto had same problem with old carby
thanks for your nelp so far.  have work commitments this week will try again on the weekend
