Author Topic: What is the best 21 inch tyre for the front of a CR250RD for dirt track (Nepean)  (Read 4193 times)
Offline oldyzman
  • 250 two stroke!
I am just considering the Knobby by Pirelli "extra X" as it seems a bit softer than the MC5 metzler that i have been using. Or should i go to a modern road trail.
Brett.
Offline Shaun G
  • Sydney, NSW
    • FULL LOAD MOTORCYCLE TRANSPORT
Brett I like the Kenda Carlsbad. I reckon knobbies are the go over a road trail at Nepean.
Shaun
Offline oldyzman
  • 250 two stroke!
Thanks 297,
Is the carlsbad a soft compound tyre.
Brett
Offline Shaun G
  • Sydney, NSW
It's an intermediate/hard terrain tyre mate http://www.kenda.com.au/products/product/K3380?category=CTTFTJMX&
Works well for me on a loose surface.
I have also been recommended a Kenda Millville by someone who knows a bit. This one is a soft terrain and has extra knobs on the outer edge. I haven't used one though.  http://www.kenda.com.au/products/product/K3280T?category=BHGTBTHX&
Shaun
« Last Edit: June 24, 2013, 06:11:14 am by 2-NINE-7 »
Offline Graeme M
  • Administrator
  • Canberra, Australia
Yes it is a soft compound tyre designed to work on hard surfaces hence the name Carlsbad which was a very hard skatey surface apparently. I find tyres an interesting question, everyone has their own idea of what works. Someone once said that a 'mud tyre' works well at Nepean but that would be a hard compound wide spaced knob.
Personally, the best tyre I have used on my YZ125 is the Motoz X-Circuit. It feels incredibly stable under brakes, hooks up in loose corners and still works well when it's dry and hard. Way better than the Dunlop MX51 I was using before that. And much better in loose conditions than the Kenda.  I reckon the Carlsbad would be good on an oiled dirt surface but I don't rate it in loose stuff...
But that's just me and I've not tried many others.
I bought a Dunlop K180  3.00 x 21" from another forum member that I doubt I'll be using on my current dirt trackers. These tyres are made for flat track and it should work a treat, the 21" version doesn't come along very often. I never got around to having it shipped from the seller so it's still at his place. if you want it I'll take what it owes me.... $60 + shipping from Steve.
Offline hagon_84
i run a kenda millville sticky as suggested by another forum member a while back it has been great hooks up well even on hard slick surface (deco track) yet to try it on loose oil track but should be sweet as from memory it was $115
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Offline oldyzman
  • 250 two stroke!
Thanks for all of your help and pastings of links, I am considering......
Firko - I will pass on the Dunlop for now thanks
Would seem the carlsbad is a softer compound than the milville...
Cheers Brett
