Author Topic: PVL ignition  (Read 4531 times)
Offline jake57
PVL ignition
« on: June 22, 2013, 03:50:34 pm »
i have a new pvl that has a very weak spark. Is there any way to check the ignition
thanks Jake
3858
Re: PVL ignition
« Reply #1 on: June 22, 2013, 04:07:56 pm »
How did you determine it has a weak spark?   :)
Montynut
Re: PVL ignition
« Reply #2 on: June 22, 2013, 04:16:01 pm »
The most likely cause is a bad earth also the PVLs do have a low spark at very low speed (kicking speed) but a fat strong spark once at idle or above.
Offline jake57
Re: PVL ignition
« Reply #3 on: June 22, 2013, 04:30:23 pm »
 thanks Monty that is what the problem is
it only just sparks when i kick it over by hand
3858
Re: PVL ignition
« Reply #4 on: June 22, 2013, 04:47:01 pm »
Mont. is right on both counts but I was going to take you there more eventually.
To answer the second part of your question is to use a Peak Volt meter on the coil and check for Ac voltages of around 150.
No one has a PV meter unless at a shop but a Multimeter averages the sine wave and may show about 70vAC on kick over... connect it to the coil input wire and earth...
Fitted two PVLs last week and a pretty easy system..
Offline jake57
Re: PVL ignition
« Reply #5 on: June 22, 2013, 06:59:58 pm »
thanks 3858
will check tomorrow
Re: PVL ignition
« Reply #6 on: June 22, 2013, 10:11:14 pm »
Don't use a resistor plug god a start.  Use an egv
Montynut
Re: PVL ignition
« Reply #7 on: June 23, 2013, 12:07:47 am »
I think you will find that the PVL instructions specifically say not to use an 'egv' plug from memory. A resistor plug is OK but not the best. It depends on the PVL is it analog or digital?
« Last Edit: June 23, 2013, 12:13:38 am by Montynut »
Montynut
Re: PVL ignition
« Reply #8 on: June 23, 2013, 12:22:30 am »
Just to clarify that a multimeter does not average the AC wave form as the average of any sine wave is zero it actually measures the RMS value which is the 'root mean square' of the wave which is .707 of the peak value. so if you measure measure 70 volts on the multimeter (RMS) multiply by 1.414 (for a pure sine wave) to calculate the peak value. Not trying to be a smart arse just thought I would clarify as electrical stuff is sometime difficult to explain.
Offline SON
Re: PVL ignition
« Reply #9 on: June 23, 2013, 04:27:03 am »
thanks Jake
Jake, to what motor have you mounted the PVL ?
And what tracks / usage do you intend ?
Offline jake57
Re: PVL ignition
« Reply #10 on: June 23, 2013, 12:05:56 pm »
problem solved .......just have to kick it harder
Son  7yz400e
dirt track & natural terrain mx
