Author Topic: Help with '84 KX125 fork assembly.  (Read 1514 times)
« on: June 21, 2013, 02:06:01 pm »
Wondering if anyone has had a pair of these forks apart, or has a manual?  I've pulled the forks apart to replace the seals and as I tipped the damper rods & top-out springs into the drain bucket a couple of collars appeared  ;-)
I need to know if these collars go above or under the circlip on the damper rod base, and does the recess of the collar face up or down?
I've checked a couple of on-line parts diagrams but it doesn't properly define the set-up.
