Author Topic: Anyone tried 11:49 or 12:53 sproket ratio (yz125d)  (Read 1894 times)
Offline Paul552
  • HEAVEN #552
« on: June 20, 2013, 08:44:31 pm »
I have 12:51 std ratio and I find sometimes I'm back to 1st gear and just wondering if anyone has tried the above ratios?
Either way I need to buy a sprocket a 11 front or 53 rear.
Also is 11 too close to the bearing housing/case bit?
Just wondering if anyone has tried it ?
« Last Edit: June 20, 2013, 08:47:01 pm by Paul552 »
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Anyone tried 11:49 or 12:53 sproket ratio (yz125d)
« Reply #1 on: June 20, 2013, 09:43:35 pm »
Off the top of my head, i cant remember whats on the back
but the fronts definately an 11 tooth on my YZ125f ( same gearbox as "D")
No clearance issues for the chain.
2nd gear starts perfect with good short course top end.
"flat bickie"
Offline Paul552
  • HEAVEN #552
« Reply #2 on: June 20, 2013, 09:51:39 pm »
That's great thats what I need!
I will try it with the 49 rear.
Thanks heaps
Offline PEZBerq
  • Brisbane
« Reply #3 on: June 21, 2013, 01:34:41 am »
11 is mighty small and will cause the chain to bend a tighter radius and wear faster than larger sprocket sizes. Larger rear sprocket is typically recommended but costs more. Perhaps not so much an issue on a 125 than an open bike?
