Author Topic: Not vmx but help needed  (Read 4240 times)
Offline steve7406
« on: June 20, 2013, 06:15:04 pm »
Went to start my 2000 yamaha wr 400 put foot on kick starter and kicked herd a tink within motor then loss of compression was allright before this any ideas what i should be looking for.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline Paul552
  • HEAVEN #552
Re: Not vmx but help needed
« Reply #1 on: June 20, 2013, 06:48:08 pm »
Decomp cable?
Or decomp mech at top of head?
Offline matcho mick
    • Moto Tumbi
« Reply #2 on: June 20, 2013, 08:18:51 pm »
your wallet  :P
« Reply #3 on: June 20, 2013, 09:32:32 pm »
What should you be looking for?......a new bike perhaps?...preferably a 2 stroke.... ::)
Offline crossedup2
  • Never enough shed time.....
« Reply #4 on: June 20, 2013, 09:55:06 pm »
The early WR / YZ suffered from sticking valves to valve guides. If they sat for a while they would loose compression. A lot of people put it down to change of brands of oil at oil changes but I won't believe that.
I'd do a proper compression test first. Then I'd check valve clearance etc. After that check valve timing (assuming the chain may have jumped???)
Good luck and let us know what it was.
Peter B
« Reply #5 on: June 20, 2013, 10:00:25 pm »
Don't take any of those idiots at face value
A "tink" noise EH??? I tink its crapped itself.... ;D :D sorry couldn't help it.....
obviously you have lost the decomp mechanism or a valve head has fallen off.
you had better get the compression checked or the valve train. but a 2000 model could have suffered a major failure.
pull the plug out and see if it is still in good condition ( light brown color, electrode ends square..) hold your hand over the plug hole and ... sorry I forgot its a 4 stroke , the plug surface is awaaaayyy down in the head somewhere..
would be good to see if there was compression still without the plug in....
Tink noise... could be anytink ..... :D ;D :o ;D
« Reply #6 on: June 20, 2013, 11:06:01 pm »
Take the valve cover off to start with and check the decomp mechanism and also do a valve clearance check, that'll give you some idea.
« Reply #7 on: June 21, 2013, 02:09:36 pm »
Once a cam chain is stretched it tends to slip on the crank sprocket during the the kick starting process, my guess is the the timing has jumped, the piston has kissed the valves bending them.  If the valves are bent I'd be replacing the cam chain or checking that the tensioner hasn't backed out.
Offline steve7406
« Reply #8 on: June 21, 2013, 07:13:11 pm »
Thanks guys will look at it tomorrow .
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
« Reply #9 on: June 21, 2013, 07:38:39 pm »
Please post a report on your findings Steve as I and maybe others are interested in what the problem be . Thanks Tim754
Offline steve7406
« Reply #10 on: June 29, 2013, 12:20:53 pm »
Finaly got the wr apart its bent a valve i would say the timing chain slipped a cog.Time now for a rebuild
top and bottom end carnt complain its the first time in 13 yrs its been apart.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
« Reply #11 on: June 30, 2013, 09:32:05 am »
On the money JO
Offline steve7406
« Reply #12 on: June 30, 2013, 04:56:23 pm »
Smart cookie jo and a good bloke with it.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
