Author Topic: CR500-88 Parts  (Read 6681 times)
Offline popeye
CR500-88 Parts
« on: June 18, 2013, 01:26:45 pm »
Has any one got a clutch cover to fit an 88 Honda CR500?
Another one with a water pump problem....
Offline popeye
Re: CR500-88 Parts
« Reply #1 on: June 18, 2013, 01:38:32 pm »
Hi Walter, mate if you could give me some idea on a price? It's for one of the bikes Greg has in the shed at home, everything else is ok just a frozen water pump, don't want to bodgy it up as the rest of the bike is in good condition...
Re: CR500-88 Parts
« Reply #2 on: June 18, 2013, 03:55:46 pm »
CR500 Forum, has great info and tech help.
everyone on the forum is A Hoon, but i am the only true Hoon.
http://www.cr500riders.com/
« Last Edit: June 18, 2013, 03:57:24 pm by Hoony »
Offline mr500
Re: CR500-88 Parts
« Reply #3 on: June 21, 2013, 09:15:59 am »
Hi mate
Not sure if your aware that any later cr500 clutch will fit?
The advantage of using the later cover is that it's made of alloy and not magneisium and will Never rot out again.
It also holds more oil because the later 500's had more clutch plates it has a cover so the clutch can be accessed without removing the whole cover.
The only modification required is to reroute one hose.
Smoke'n..
Offline mr500
Re: CR500-88 Parts
« Reply #4 on: June 21, 2013, 09:24:36 am »
Hi mate
Not sure if your aware that any later CR500 clutch cover will fit?
The advantage of using the later two piece cover is that it's made of alloy and not magneisium and will Never rot out again.
Smoke'n..
Offline Maicoman
Re: CR500-88 Parts
« Reply #5 on: June 21, 2013, 10:58:48 am »
Forum member AdamN has a Nos cover from a 91 model for sale. This seems to be the go to modify a later model cover to fit the earlier models. Due to the low boy pipe and hose route on the 91 some changes need to be made and you have to machine the cover for clearance of the clutch.
« Last Edit: June 21, 2013, 11:02:42 am by Maicoman »
Offline popeye
Re: CR500-88 Parts
« Reply #6 on: June 21, 2013, 08:03:16 pm »
Thanks guys, Adam has set me PM and I'm just waiting him to get back to me....
Thanks for the info....
