Author Topic: Steering ball race removal  (Read 4305 times)
Offline AJ
« on: June 13, 2013, 06:38:17 pm »
I'm restoring a CR125m1. I thought the steering ball races would tap out of the frame easily, but they won't budge.
I presume heat will help, but the frame has already been done in 2pac.
Any hints?
Thanks AJ
Offline kdx Geoff
Re: Steering ball race removal
« Reply #1 on: June 13, 2013, 06:57:12 pm »
Do you plan to keep them to reuse ?
If not, get a bigger hammer, they've probably been in there for years, and get the frame on something solid so the energy for moving the bearing doesn't get lost with the frame moving about.
Offline Paul552
  • HEAVEN #552
« Reply #2 on: June 13, 2013, 07:50:00 pm »
The easiest way to remove them without wreaking seat they sit in is to run a bead of weld around the race. Let it cool and it shrinks and the race will fall out.
I saw this in ADB and I couldn't believe how good it works.
I wouldn't bash them as the seat will wear and then what do you do.
Hammer is not a tool !!
Offline Paul552
  • HEAVEN #552
Offline frostype400
« Reply #4 on: June 13, 2013, 08:21:06 pm »
There's a tool you can buy so easy to do it then here's a link http://www.parktoolmotorcycle.com/frame.html
I have the rt1 and rt2 steering race removers.
1971 tm400 and PE's
Offline AJ
« Reply #5 on: June 13, 2013, 08:57:11 pm »
Thanks for the ideas.
I'm not keeping the races as the are the original loose bearing ones.
Is there a lip the race sits in or is the frame tube the same diameter all the way through?
AJ
Offline kdx Geoff
« Reply #6 on: June 13, 2013, 10:35:44 pm »
The bearings have a seat that they sit against, going out its the same diameter, when you fit the new bearings you need to make sure the new bearing is hard up against its seat.
However you choose to apply pressure to the bearing to remove and refit, it needs to be on the outer race as that's where the friction is.
Offline steve7406
« Reply #7 on: June 14, 2013, 04:29:15 pm »
Where in Aus can you buy rt1/rt2 steering race removers
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline AJ
« Reply #8 on: June 14, 2013, 04:41:32 pm »
Steve Cramer Products in Vic are the distributor.
I called them & they said RRP is $44.95 & they have both the RT-1 & RT-2 in stock.
As they are the distributor he said just order through your local bike shop.
AJ
Offline steve7406
« Reply #9 on: June 14, 2013, 04:46:36 pm »
Thanks AJ will order both first thing Monday.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
