Author Topic: smooth out an 87 CR250  (Read 4196 times)
Offline TheDamo
« on: June 10, 2013, 04:42:55 pm »
Hi Guys,
Has anyone had experience with smoothing out the power on an 87 CR250?
Some more bottom end and transition to mid range would be nice.
Re: smooth out an 87 CR250
« Reply #1 on: June 10, 2013, 05:07:31 pm »
Do you want the easy or the hard way?
Offline Paul552
  • HEAVEN #552
« Last Edit: June 10, 2013, 06:44:23 pm by Paul552 »
Offline TheDamo
« Reply #4 on: June 10, 2013, 07:51:31 pm »
Gimme both thanks
Offline Damo
« Reply #5 on: June 10, 2013, 08:47:33 pm »
Boyesen Rad Valve and Keihin 38mm Airstriker
« Reply #6 on: June 10, 2013, 11:11:53 pm »
Gimme both thanks
We'll start with the easy way. Machine a 50mm spacer  minimum 2mm LARGER ID than the exhaust duct outlet, Then fit that between the pipe and the cylinder. Test. Measure stinger/tailpipe ID(usualy 27mm).
Offline whitey 43
« Reply #7 on: June 11, 2013, 08:28:04 am »
From what ive heard, you can buy a flywheel weight which screws into the puller thread...It works really well on the late 80s cr 250s, & would smooth your hit out & make the power more useable.
« Reply #8 on: June 11, 2013, 08:31:12 am »
How is the needle jetting? if its rich it will give a harder hit as it transitions than if its spot on?
got blubbering and drag at 1/4 to 1/2 throttle ???
